Tom Wrote: NEVER use rags or paper towels of any kind on any engine
part to be rebuilt unless you want to risk engine failure.
Tom,
That's why I stated "lint free" rags and my use of them was to clean
honing contaminates out of the pores in the cylinder walls. They have a
mil spec and they are not cheap. I agree with you and should have
stated that that I have two solvent tanks. One for dirty parts and one
for final cleaning. I always use bore brushes to clean oil gallery
passages, block & crank. After I get a block back from the machine shop
I never spend less than 2-3 hours cleaning it, and whatever amount of
time it takes to deburr it. I also use scotch brite pads and clean
solvent to gently scrub the bearings prior to a final bath in laquer
thinner. All parts (except lifters) get the laquer thinner bath and
blow dry as a final cleaning.
Tom wrote: Putting the block or crank in the jet washer is a no no.
I agree, that's why I said pressure washer. Hand held with 3,000 psi
followed up with air. This is after final machine work and before the
crank or block leaves the shop. I clean it again in my "clean" solvent
tank after I get it home.
Tom wrote: Anyone know how to properly center the thrust bearing in the
block?
Yes.
Steve Ferguson
San Diego
Tom,
block?
Yes.
Steve Ferguson
San Diego
