I can tell you that both Dave and I can tell you that going to one ton has
its issues.
Since Dave and I know how to make the origional system work for 80-100,000
miles , your not doing justic.
People like Bob Duahugh and others can explain the short comings of One
ton, we do sell one ton, so figur that one out.
> Brian W.:
> Send an e mail to attn of Bob Dunahugh in Cedar Rapids, Iowa.
> He is very knowledgeable re GMC's and has friends and family in the twin
> cities area of Minn. He could possibly tell you who could help.
> Mike/The Corvair a holic
> Sent from my iPhone
> > No I do not know of those 2 guys...how would I contact them?...where are
> they?...who in or around twin cities...dave L. could not think of anyone
> ther e when I talked to him bout 1.5 year ago....Brian 77 ele winnipeg
> > ________________________________
> > From: Gmclist on behalf of Billy
> Massey
> > Sent: January 7, 2018 5:11 PM
> > To: gmclist
> > Subject: Re: [GMCnet] bearings
> > Have you checked with Tom Struthers and or Harold Kihn? Otherwise,
> nearest
> > agglomeration of GMCers in the know would be around the twin cities.
> >> On Sun, Jan 7, 2018 at 5:45 PM, James Hupy
> >> You are not too far from Cinnabar. $$$ but they do know GMC's.
> >> Jim Hupy
> >>> been through this but thanks for the suggestions...new BFG radial 16
> inch
> >>> with new alcoas varied psi...no change...new hub extensions on and
> >>> off...no change....new relay and pitmann and alignment and other pivot
> >>> point arm (forget name)...no change and steering linkage and steering
> cv
> >>> new lube and tolerences checked and taken off and tried and tried
> >> different
> >>> positions on that blue telescoping shaft and everything is tight and no
> >>> change...steering box maybe next but would like to do the front wheell
> >>> bearings anyway..... by driving it somewhere......where???..Brian 77
> ele
> >> 455
> >>> From: Gmclist on behalf of James
> Hupy
> >>> jamesh1296>
> >>> Sent: January 7, 2018 4:27 PM
> >>> To: gmclist
> >>> How about tires? Are you running all steel belts, or steel belt treads
> >> with
> >>> rag sidewalls? Inflation pressures?
> >>> Jim Hupy
> >>> replaced the rear bearings and did all measurements on the bogies
> >> ....solid
> >>> tight and nothing bent...Brian 77 ele 455
> Hupy
> >>> jamesh1296>
> >>> Sent: January 7, 2018 3:59 PM
> >>> To: gmclist
> >>> Brian, remember this point. "When you can't figure out why you coach
> >> won't
> >>> steer, look to the rear end. The back end CAN and DOES steer the
> coach."
> >>> Particularly the forward bogies.
> >>> Jim Hupy
> >>> Salem, Or
> >>> 78 GMC ROYALE 403
> >>>> On Jan 7, 2018 2:08 PM, "Brian Waddell"
> >>>> I have not used my 77 gmc elegansa mostly because the steering is so
> >>>> bad...I have replaced most components ordered from Dave L.....might
> >>> replace
> >>>> the steering box next...I have discussed steering issues with the
> >> gmcnet
> >>> in
> >>>> the past. I have new front bearings and seals from Jim K. I bought
> >> them
> >>> a
> >>>> few years ago but decided not to install them as I know I am not
> >>>> qualified...So my question...Me and the gmc are situated near Winnipeg
> >>>> Manitoba Canada...grand forks Noth Dakota 125mi. or so south...Where
> is
> >>> the
> >>>> closest place I could drive this coach to have someone qualified do
> >> front
> >>>> wheel bearings etc with grease fittings?..
> >>>> brian 77 ele 455
> >>>> _______________________________________________
> >>>> GMCnet mailing list
> >>>> Unsubscribe or Change List Options:
> > Gmclist Info Page - GMCnet mailman/listinfo/
gmclist_list.gmcnet.org>
list.gmcnet.org
> > To see the collection of prior postings to the list, visit the Gmclist
> Archives. Using Gmclist: To post a message to all the list members, send
> email ...
> >>> Gmclist Info Page - GMCnet >>> mailman/listinfo/
list.gmcnet.org
> send
> >>> email ...
list.gmcnet.org
> send
> >>> email ...
> >>> GMCnet mailing list
list.gmcnet.org
> send
> >>> email ...
> >>> GMCnet mailing list
> >>> GMCnet mailing list
> >>> GMCnet mailing list
> >> GMCnet mailing list
