I have sent everyone on my wheel puller list an e-mail including pictures of
the puller etc. If you did not receive this private e-mail than there was
either a problem with your ISP or your e-mail address. Contact me via
e-mail if that is the case. so far I have received 21 confirmations out of
50 who said they wanted to buy the puller.
For others that have sent e-mails to me asking if purchase of a front wheel
bearing puller is necessary. In my opinion it is one of the most sensible
purchases you can make, whether you are doing the work on your own coach or
having someone else do it. Very, very few individuals or shops have the
proper tools to remove and reinstall the front wheel bearings correctly. I
have seen shops use cold chisels taking bearings off the hubs or Toronados
(it works but one careless slip can ruin your hub), use a torch to melt it
off (careless use of to much heat could change the grain structure of the
hub material and weaken it). Why take a chance? If you have your hubs
serviced by someone else, buy the puller and let them use it.If you also buy
a copy of the June 1996 issue of GMC motorhome news than he will have a step
by step procedure to follow complete with picutes.
Netters have gotten together and are having the wheel pullers manufactured
for a complete cost of $180 a set. You will never wear it out.
If anyone still wants to be added to the list send me an e-mail.
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
"The beautiful Mohawk Vally"
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
