Bathroom light switch
boybach
1,069
224
63
I replaced all the OEM interior light fixtures in my coach with duel intensity LEDs several years ago, but kept bathroom fixtures as they were, just swapping out the bulbs to LED as I wanted to retain the 3 position function. As I remember, the length of the unit wasn't easy to match up to a replacement.
The LH fixture rocker switch has always been a bit temperamental, needing a bit of "jiggling", so last week I gave the switch a good squirt of contact cleaner and it seemed better. Yesterday I tried the switch and it didn't work at all - no matter the position.
Can the switch be disassembled and repaired or is that a waste of time? Has anyone replaced the switch with an OEM style if one is still available? I see a bunch of 3 pole switches on amazon and I suppose I could fabricate a mount ...
I don't mind replacing the fixtures either if I can match the dimensions.
Any tips?
Thanks
Larry
CRC QD Electronic Contact Cleaner spray. Ten bucks at Amazon, same price for a larger can at Home Depot.
Leave the switch where it is - spray a small amount into the contacts and it should work.
My dad was a radio/radar technician for US Navy (1950-53), always had 'tuner lube' handy.
When his Radio Shack tuner lube finally ran out, found CRC QD was equivalent.
My mom's washing machine quit working 7 years ago. I sprayed some on the timer switch, it's been running fine since then.
I already sprayed it, see my original post :) Thanks anyway!
Any tips?
Thanks
Larry
Here is a link to a spec sheet for a company that make multi-position slide and rocker switches. Your will need to read through to find a switch compatible with your needs. You may need to add a diode or two to make one work. Once you find the part number, look for it on a electronic distributor's site. I would suggest Digikey since they will usually ship single quantities and the shipping and Brokerage fees are only $8.00 Cdn.
Here is a 3 position slide switch with screw mounting tabs for $3.71 Cdn + $8.00 CDN shipping You will need to determine from the spec sheet listed above if it is compatible before ordering.
Reactions: dsmithy and boybach
If it doesn't work at all, I'd say take it apart. It sounds like there's nothing to lose at this point.
I think what prevented me from doing that in the past was seeing they were soldered in, and feeling too lazy to address it at the time. Maybe it's doable in place though. I've taken many switches apart and made them work again over the years. I'd bet you just need to carefully bend some tabs and slowly pry apart watching for the flying bits.
  • Haha
Just what I've observed after swapping all the bulbs out for LED, the switches are more finicky now.
IMO the extremely low current of the LED exasperates the dirty electrical connection in the switch. When they were pulling a full amp the connection would be made, but now they're only a few milliamps.
That's my plan now, although this one looks a bit complicated for a light switch, lots of connections :unsure:
Also available is Switchcraft 46313LDRSX, which can be had from Mouser, but not Digikey., for $13.99. This is an open-frame switch, so it will be easier to shoot contact cleaner into in the future without disassembly (but it also lets more contaminants in).. Switchcraft has or used to have a pretty good reputation. I don't think I've heard of CW Industries.
The light needs a DP3T switch with shorting bars, which is something of a specialty item.. The switch has three positions over four contacts, with contacts 1-2-3 or 2-3, or 2-3-4 being made. This is what you need to make the off/on-A/on-A+B function work. The pinout is P-A-B-P on one side, A-G-B-NC on the other side, where A and B are the lamps, P=12 VDC, G=ground, NC=no connection. (I had no luck finding a true off/on-A/on-A+B switch except for a big ol' thing made for British motorcycles and another, even bigger switch made for boat lights.)
I'm not positive the Switchcraft switch or the CW Industries switch will fit the chassis without modifications. I'm going to order one switch from each manufacturer and see which one works best.
I really like the look of the PD750 lights with their little woodgrain accents...I'd like to keep them going as long as possible. Unfortunately, Progressive Dynamics discontinued all their lighting products several years ago, but the lenses are still available as NOS.
This concludes my rabbit hole travels for this evening. :-)
