Thank you Ken. Well, I will just mothball the gasket and find an installation center near me that works with Coach Glass.I thought I replied to this but it sure is not showing up right now.
I talked to Paul owner of PDK (Preferred Glass). He said in 35 years and over 200+ GMCs he can remember doing three new gaskets when they replaced the windshields. I asked about sealing the gasket to the body when installing it prior to the windshields being installed. He said the way they seal the windshields to the coach body that the added sealant you are talking about is unnecessary. He would not do it. He said if you choose to do it, the only possible problem he sees is if they take too much time between installing the gasket and installing the glass and that time allowed the sealant to set up or even partially set up. Then there is a chance that the windshield could be broken during install or later while driving down the road. He said to only seal one side and immediately install the windshield. Then seal the gasket on the other side and immediately install the second one.
Again he said he would not do it. Just seal them like you see in the video and you should be OK.
Ken B.
Update: I discovered the following image in the Dealer Service Technical Bulletin number 75-TM-10 A Water Leak Diagnosis and Correction.
