It’s finally raining out here in CA and like clockwork the windshield gasket is leaking. It’s about an inch from the rear view mirror bracket and the gasket has a bump in it with water dripping over it (expand image). Because my MH is parked in the driveway at about a 2% grade uphill and leaning slightly to the passenger side, the water is also leaking over the passenger seat area where your legs would reside.Larry, if it's dripping near the steering wheel or cockpit seat then it could very well be the gap between the windshield gasket and front body cap. It's a known issue that Jim Bounds has posted about. There is a void in the body from the manufacturing process of the front cap mold that was filled with sealant and over time leaks. The void if I recall is close to the rear view mirror but the watwr can travel left or right. Sealing between the gasket and body works.
I had this and Sealing it worked. But you do want to be sure it's not the roof to cap seam, and marker lights as well.
HTH
Dave
Ed
