Alternator Anomaly - Problem Solved
Stu Rasmussen
132
Thanks Bruce - having that document cleared everything up.
Turns out the 2-wire connector with battery on one pin and dashboard
indicator on the other was backwards.
That's the way the coach was when I received it and having your provided
schematic and thereby knowing which terminal was #1 and #2 it was a
quick fix to reverse the connector.
Strangely enough, this connector can be inserted into the alternator
either correctly or 180 degrees out - it slips in nicely either way.
Not quite idiot proof. At least not for this idiot.
Methinks that alternator PDF should be added to the Flash Drive. Worth
its weight in platinum!
Thanks!
> Stu,
> Have you metered the 2 pins to see which pin is wired to the battery Sense wire and to be sure the Sense wire is going to the correct alternator pin?
> Here is an excellent Delco service manual on our alternators:
> http://www.gmcmhphotos.com/photos/data/6522/Delco_Alternator.pdf
That ORIGINAL connector was polarity conscious. But these coaches have ALL
been altered from their original state, some everywhere you look, some not
so much.
Just about the time we think we have our coaches idiot proofed, along
comes a better class of idiots to disprove that theory. The FACTORY wiring
diagrams are most often correct. Especially Ken Henderson sons large print
versions. Double check EVERYTHING.
Salem, Oregon
On Thu, Jan 2, 2020, 1:40 PM Stu Rasmussen (97381.com) via Gmclist <
> Thanks!
> > Stu,
> pin?
That plastic moulding use to be available from Auto Zone and Rock Auto in case you want to change it.
Napa part Number
https://www.napaonline.com/en/p/ECHVRC148?searchCategory=c11.s2&searchIndex=Universal
On Fri, Jan 3, 2020 at 1:17 AM Ken Burton via Gmclist <
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
