David,
You need to remove the hub and press them out with a hydraulic press. A
simple job with the proper tools - just be sure that the hub is
supported properly and be careful - it takes a lot of pressure to break
the old studs loose.
Patrick
> When replacing the front wheel studs to use the Alcoa wheels how do you get
> the old ones out? Do you knock them out with a hammer or is there some way of
> pushing them out? Do you have to remove the hub to put the new ones in?
> David
Patrick Flowers
Mailto
atrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
Patrick
> David
Patrick Flowers
Mailto
