Thanks, Matt
jof
----- Original Message -----
Reply-To:
To:
Sent: 11/20/2018 3:23:40 PM
Subject: Re: [GMCnet] 403 Distributor
________________________________________________________________________________
> On my 403 engine coach, every time without fail for the last several years, when it sets for several month, I have to pop the distributor cap and
> polish the points with rough paper or fine sand paper. They look fine but just need to be cleaned, polished, whatever; then everything runs fine.
> Why? I don't know. Replacing didn't seem to change anything either.
> jofarr
> soddy daisy tn
> 74 canyonlands, 76 custom and 78 28 footer Curtis classic
> Jesse, 403 engines were fitted to GMC coaches in 77 and 78. Points distributors were discontinued in 1976 when the HEI distributors were
> introduced and they did not have points. Your coach is unusual if it has points, although it is not unheard of for someone to back fit to a points
> distributor.
Jess,
Jim has a very good point, but only one of three that you should think about.
It is has points, then it was probably back fit by someone that got tied of HEI blowing out because it could not reliably run the specified gap at
motorhome loads.
If you want to keep running that distributor, go get a Pertonix 1181LS to replace the points. Even with decades of experience with points (Kettering)
ignition, I still don't like them.
If you have a points type distributor, it can't be for/from a 403. The curves are probably wrong. Get with Dick Paterson and figure out what you can
do.
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
