Got the driver's side control arms off tonight. Kinda bummed. My bogie pins are trash... Especially the driver's rear. It was seized in place. Needed my 20T press to get it apart. The funny thing is that the bushings look decent. Not sure why the bronze bushing wore a steel pin, but it did.
I see JimK sells a replacement set (cha-ching!) And I'm sure I can get them from cinnabar too. Any one used Jim's? Are they better? He says the pins are hardened, and seeing the wear, I'd say factory are not that hard. I have a Rockwell tester at work, so I can see exactly what they are.
Finally... The pin that is real bad has much smaller grease holes in it. They were completely plugged, so I'm sure that's what caused this issue. I couldn't grease them if I had wanted to. Why the different sizes?
other issues...I noticed that the suspension carrier that bolts to the frame was trapping water... And I have some thinning of the material there... It's not rotten through. Should I come up with a plan to replace the metal or just rely on the sandwiching of material there? I have a couple ideas already on replacement. I have rotten shims too, so I'll have to replace those.
What a night... Labor of love, right?
