The the dash back in the coach the next thing to do is the Instrument Panel. I'm kinda rolling my own here, instead of just taking the easy way and buying something from Custom Instrument Panels (of Mac Dash fame). I read a Hagerty article about the GMC coach that Pontiac dolled up for its Trans Am Territory marketing rig. I REALLY liked how that dash came together, so that is my inspiration. In case you don't want to go back and look through the thread...
This project has been taking up most of my time this summer. Its nice, cause I can work on it at my house when I have a free minute, instead of going to my folks (where the coach is).
Here is the dash panel, with new steel added and cutouts made for the additional gages.
Some changes from the inspiration. I added a trans temp gage and will be using an 8" tablet style single DIN radio. That will give me in dash nav and a back-up camera, plus the ability to stream Blue tooth and connect my phone. I also swapped the heater controls and radio. Just thought it would be easier to have the screen higher in the IP and closer to my line of sight.
The square hole is the new Tell Tale display I created. Instead of laying them out lengthwise, I stacked them. It was the only way I could fit all the gages and information I wanted. You also may notice that there are no switch install holes. I'm eliminating the battery boost switch (since I have LiIon house batteries) and the Main/Aux fuel switch will live over by the headlight switches. That is the last hole I need to make (still, actually).
Anyway, here is a mock up.
And, some of the gages with the lights on. The gages were a bit of a project. Had to clean them up, so there are new faces that I printed out on them. They match the originals though, so hopefully they last. I also printed a matching face for my autometer trans temp gage.
Dash lights on.
Another change from the inspiration is the addition of the shift range indicator. I pulled the swing needle from the GMC gage and build a spot to house it in the T/A gages. I need to add some gasketing to the box though. I'm getting too much light bleed, IMHO. I also need to print the label for it.
Here it is in daylight.
Very soon, this stuff will be mounted in the panel and I'll have to figure out some sort of beauty ring / bezel to cover the mechanicals. I may stick with the original, since its ABS plastic. With a couple sheets of plastic and my 3d Printer, I can add and subtract material just like if it were steel.
Finally, the steering wheel. I never liked the factory wheel. I think it blocked too much of the panel, so I found this guy.
I really wanted the center to be GMC, so I made a new "button."
And, Finally, I cleaned the nasty old plastic...but still didn't like it. Too thin and hard. I wrapped some mason string around the rim to increase the diameter, then used one of the cheap hand stitch wheel covers from Amazon to make it nice and soft in your hand. It actually turned out WAY better than I expected. Last thing to do is either wrap the horn section and back bezel with my dash vinyl or paint them to match the plastics in my coach.
View attachment 16328View attachment 16329
