I would like to verify something. My battery boost system does not work.
I have the
installed. The Status connector on the ACR-160 is connected to Y in the GMC diagram (the orange wire from the Front AUX BAT SW) and the Minus connector is connected to ground through a 5A fuse per ACR-160 wiring diagram.
I am not getting 12V power to Status connector when switch is pressed. House Battery and Engine Battery is at 12.6V, and the 5A fuse is good, and house battery is charged at 12.1V. I assume both battery systems are providing 12V to the boost switch.
I assume the diagram from GMC above shows the momentary switch when it is NOT pushed.
Can an expert please verify that when it is pushed, the two paddles connect to the two terminals below in the diagram? The left paddle provides power from 5A fuse from Engine Battery to the terminal below it (Y and S are connected to it) , and BAT NORMAL goes to BAT BOOST (S and Y are connected to it) providing power from House Battery. The jumper between the two lower terminals make sure power gets to S and Y from 5A fuse and/or House Battery.
R takes "fuse link" power from the long house battery wire, with the connection under the hood after the diode. I assume this powers the switch if the engine battery is dead (labeled as AUX BAT above).
Y sends 12V+ to the coil of the "Front AUX BAT SW"
and
S sends 12V+ to the coil of the "Rear AUX BAT SW".
I have this wiring diagram
https://www.gmcmi.com/wp-content/uploads/2020/03/78-chassis-electrolevel-II.pdf
This is making me nuts. I may have to take dash apart to pull boost switch to bench test it and related wires.
Thanks,
Paul
