Bought this beast November of 2021 for $14,000
https://www.gmcrvforsale.com/1978-eleganza-georgetown-tx-2/
Here is what I have done so far 2021-2025
Running Tally of Total Spend $6,769.81
Applied GMC purchases September 2022 Total $2,337.16
Amazon Purchases for GMC Fall 2022 Total $731.54
Amazon Purchases for GMC Spring 2023 Total $806.11
Work done by Fred Generator Repair (pre-paid for by previous owner) $0. (Valued at $3,000)
Venmo Payments
- Brake parts and tune up items. $1,794.80
- Air bag parts, carb parts, trans gasket, air filter $340.34
- Window Felt, Side Vent, Exhaust parts $202.02
- Wire covers: $28.09
- GM power brake booster vacuum check valve $15.98
- GM coolant sensor $19.04
- DOT air line male connector 10.55
- Power steering hose return line $16.50
- Fresh air hose to carb parts, running lights $49.59
- Misc Parts for GMC $48.56
- Switch for engine light $11.90
- Speed nuts for grill $8.06
- Air tubing for air bags $16.24
- Air line sealant: $29.97
- Air tubing for compressor: $40.58
- 50A power cord $256.44
- House/Engine battery charge isolator: $116.23
- Sound deadening mat for Generator compartment $63.81
- ViAir Compressor, Tank, Fittings, and mounting bracket
- Remove exhaust pipe placed on rear ladder
- Refill and recharge both 6v house batteries
- Remove old diode battery isolator and install new house/engine battery isolator
- Clean up wiring in engine compartment, verify charging system works properly
- Install ViAir compressor and 1.5gal air tank by engine battery
- Install air line with regulator to allow airing up of tires/bikes etc under hood
- Remove Electro-Level sensors that no longer operate (keeping old sensors)
- Remove Electro-Level compressor system (keeping old compressors)
- Relocate Electro-Level switches behind driver armrest (keeping old switches)
- Install new airbag switches with gauge in the driver area
- Run new airlines to from driver switches to compressor and left/right airbags
- Install marine water heater, connect to engine coolant lines and 110V in bathroom
- Repair plumbing in bathroom and test/repair any leaks
- Repair water holding tank, add new line to fill spout, verify pump works properly
- Repair water drain to holding tank and add drain to kitchen water lines behind closet
- Paint window trim black
- Replace microwave oven $350
- Remove settee/bed assembly in rear and all overhead cabinets for repair
- (to do) Get settee reupholstered and rebuild settee area and related woodwork/cabinets
- (to do) Replace 120V inverter to refrigerator and verify proper refrigerator operation on 12V and 120V power
- Take coach to Fred in Leander Texas to have him rebuild generator
- Remove and rebuild generator, install new starter, filters, fuel pump and muffler
- Insulate compartment with sound deadening material provided
- Reinstall generator
Venmo Payments
- Cash to Don, down payment $500
- Battery 9/1/2023 $200
- Gauges 8/8/2023 $300
- Steering 6/9/2023 $300
- Tune/brakes 2/14/2023 $800
- Replace front rotors with rotors provided
- Repack front wheel bearings and CV boots
- Replace front brake calipers, hoses and pads provided
- Replace brake booster and master cylinder provided
- Install brake vacuum pump provided
- Adjust parking brake system
- Replace brake PVMH proportioning valve provided
- Remove/replace all rubber brake lines
- Replace rear brake cylinders (4) provided
- Turn brake drums as needed (4)
- Replace rear brake hoses provided
- Replace brake shoes and hardware provided
- Repack rear wheel bearings
- Repair air bag leaks
- Change transmission filter and oil with new fluid
- Change engine oil and filter with new fluid
- Repair power steering squeaking and replace belt
- Install, new belts routed properly as needed
- Inspect engine coolant and replace if needed
- Install OEM water temperature sensor
- Fix Digipanel temp sensors for transmission oil temp
- Don replaced gauges with mounted gauge pack on dash
- Fix exhaust leak at engine manifold
- Rebuild steering assembly column and remove play in tilt steering system
- Replace power steering gearbox
- Repair steering coupler and install new gasket/cv joint
- Inspect and repair any worn steering components
- Lubricate front suspension
- Adjust steering geometry to factory specifications
- Replace engine battery
- Adjust and Bled brakes, purchased bleed kit for $125.00
- Brake fluid $20.00
- Wash undercarriage
- Fix Oil Dipstick tube ($100)
- Fix cracked exhaust manifold ($200)
