I'm leaking a bit of oil. Every fillup I'm going through a quart of oil It's all over the bottom of the coach, and it's coated the rear window. Bad.
There seems to be oil coming from all over. There seem to be a few likely areas of concern.
One spot seems to be the distributor. I marked the position of it and pulled it and the o-ring looks like this:
Kind of flat! And hard, it broke being removed.
AutoZone has the o-ring for a couple bucks, but not in stock. I measured the hole in the manifold:
and it measured 1.500". Look at all that oil!
The shaft measured 1.290 :
I have a cheap nitrile o-ring set from Hazard Fraught
https://www.harborfreight.com/382-piece-o-ring-assortment-67554.html
and there's a 1.500 OD 1.250 ID o-ring, 1/8" thick. That must be it. In place it measured just over 1.500:
I cleaned up the area around the distributor with towels and then brake cleaner and reinstalled the distributor. We'll see, time will tell if this leak spot has been eliminated.....
I do have UV dye in the motor oil and a UV flashlight to look for leaks.
I've also sprayed down the engine with Simple Green and pressure washed it with hot water.
Next up: The oil filter housing gasket!
