We had some good weather coming up so it was time to reseal the passenger side 'rail' dripedge. This side was actually less molested than the driver's side, probably because there was an awning track screwed to the roof above the drip rail, so the PO couldn't get his silicone caulk gun on the top edge. The big take away lesson is that the original seal was foam tape stuck to the rail pressed against the roof after install, and there is no sealant in the groove.
Immediately after removing the rail. Notice the only black gooey sealant in the area of the groove is whatever may have squeezed out from under the roof panel. No significant, deliberate application of sealant in the groove. The only seal was along the line of rivets on the roof panel.
Here's the rail immediately after it was removed, it's upside down so the bottom is the top. Notice there is no sealant on the ridge where the screws go through into the groove. Also notice the only seal is between the upper part of the rail and the roof panel, that black strip used to be foam tape.
Gasoline works the best for cleaning this up. Putty knife, paper towels, gas, and wire brush:
Extrusion before cleaning:
Extrusion after cleaning:
Dry fit, make sure it goes on ok, and tape for Wurth Seal and Bond:
Tape it off top and bottom:
With a helper, practice holding the rail about a foot away from where it is going then bringing it straight in towards the body. A pair of marks on the tape help to get the screw holes aligned properly while installing the rail onto the Bond and Seal.
Cut the Wurth Bond and Seal so it gives a 5/16 bead or so, and apply it to the roof right straight across the center of the line of rivets. This puts it on the upper half of the rail and you should get some squishing out of the joint onto your tape on the roof. Naturally, after this photo was taken I was in such a rush to get it on the roof and get the rail in place that I didn't take a picture of the bead on the roof.
In places where it didn't squish out of the rail, I ran the Bond and Seal into the gap, pushing it under and filling under the rail, then cleaned up the fillet with my finger. Then peeled off the tape strips leaving this:
You can see here where the Wurth Bond and Seal has created a water seal between the roof panel and the drip rail. This is where the original seal was a 3/4" wide strip of foam tape:
