You really want to improve engine cooling the most.
Bob Dunahugh
2,784
4
3
You must go look/then copy what GM did. On any GMC that came with a 403. Mid 77, and all of 78. Plus, as Ken H said. Great added storage for fluids, and funnels. Back when I was a member of GMCMI. And showed up with my enclosed, 24 ft trailer. At the Spring, or Fall events. (Great club.)That trailer caught people's attention. Never had cooling issues with that load at 24,000 lbs. GVW.
About 20 years ago. If you had a 403. You'd get. Too bad that you have a 403. You need to get a 455 in there. Trailer or not. Then Jim K at Applied GMC came out with the 3:70. THAT was a game changer for both engines. That 3:70 also improve engine/trans cooling. Plus put the 403 into its happy power RPM power band.
Bob Dunahugh
78 Royale since 2003
4 COPO Yenkos
Bob,
So many people are not aware of the torque curve and have not spent much
time trying to understand .
I for one am never afraid to confer with people that have knowledge and
experience in those area.
> Bob Dunahugh
> 4 COPO Yenkos
Jim Kanomata ASE
http://www.gmcrvparts.com
Having a whole bunch of experience with similar engines, (455-vs.-403) and
recalling those experiences, I would have to state my preference for the
403. You put that sucker on the "sweet spot" of it's torque curve and it is
more than a match for a 455.
And yes, the 3:70 gear ratio in the final drive completes the
package, along with advancing the CAMSHAFT timing about 4°. Turns it into a
whole different critter. Wouldn't trade my 403 straight up for a 455. Your
opinion might vary.
> Bob,
> with
> into
> > Bob Dunahugh
> > 4 COPO Yenkos
> Jim Kanomata ASE
> jimk
> 1-800-752-7502
ok lads newbie here, how much money and how much work to fit one of these to my 403
Larry
Larry - Victoria BC -
If you have access to an existing coach with the 403 ( late77 or 78), Then
you can just copy what is in there. Easiest Way, I would think.
> to my 403
> Larry
I have a 77 with a 403, not sure what you mean by "copy what's in there?"
Larry
The front air baffles were on the 77 403 & later coaches. Number of albums on the photo site.
http://www.gmcmhphotos.com/photos/gmc-part-numbers/p63294-air-baffles.html
http://www.gmcmhphotos.com/photos/gmc-part-numbers/p63295-air-baffles.html
and Ken H Baffle setup
http://www.gmcmhphotos.com/photos/g6117-grille-to-radiator-duct.html
Look at all the pictures in this series and read the captions under the pictures.
Do not use plywood in the engine compartment. Use the materials suggested by Ken.
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
Michigan
> Larry
Jim was confused. He thought you asked about installing a 403 engine in place of a 455....
as for 3.7 final drive, applied lists them @ just under $2000.00 but add in a core, shipping and taxes, probably $2500.00
then you have to swap it out.... can be a fairly easy DIY, or who knows what a shop might charge.
Applied GMC is I believe the sole supplier of the 3.7 final drives.
Jon Roche
75 palm beach
St. Cloud, MN
RPMs help cooling. More trans fluid to the cooler, More engine coolant to the radiator.
All engines have what is sometimes known to as sweet spots in their RPM ranges. AKA. Peek area of the torque curve. That sweet spot is mostly determined by the cam profile. ( Shape. ) The 455's start at about 2700 RPMs I believe? Maybe lower. Not sure. I'm into 403s. The 403 seems to start at 2950 RPMs. These sweet spots generally occur in a 300 RPM span. Also determined by the cam. Peak HP/Torque also occur in this short range. And that is at full throttle only. Stock FD is 3:07. That's 3.07 turns of the engine. To 1 turn of the tire. There are 3:21,3:42, 3:55, 3:70, and 4:10 as options. 3:21,to 3:55 do help. But just not there. Why go half way? And doesn't get your engine into its most efficient operation RPMs. So, you can run a higher engine vacuum. That's where the higher gas milage is.
For some reason. There has been this fear of RPMs. With GMC owners. One of my road race Yenkos has an idle of 2200 RPM. Runs in the 7000 range. With stock GM crank/rods.
Bob Dunahugh
4 COPO Yenkos
Remember, the core deposit is refundable charge.
> to the radiator.
> Bob Dunahugh
> 4 COPO Yenkos
Jim Kanomata ASE
Ok lads, I'll look in the archive/check out what's involved in swapping out the final drive.
Other than the delivery drive 3 months ago (600 km through the coastal range, B.C.) she's yet to make her maiden voyage as a freshly all fixed up
coach. I'm planning on taking her up island next week or so, first part of the trip involves a steady climb of about 10 miles so I'll see how that
goes. Of course on the delivery drive there were plenty of ups and downs too so not really a new experience. I do fancy a 3.7 though from what you
guys are saying ...Maybe when the border opens up, I'll go to California and buy one for cash!
Larry
I had a newly installed 3:70 in my 403 equipped coach when we did a
Cross-Canada rolling rally led by Duane Jacobsen from White Rock, B.C.
He thought it might to be cool to take us to Whistler Resort via some
1st Nation goat trails. 18% uphill grade for 26 miles. 1st gear, foot to
the floor, 3600 RPM grind it out. Same deal on the other side, but
downhill. Sure glad I had that 3:70. Not sure if the 3:07 would have made
it. Best single improvement that I have done to my coach. Most noticeable
performance gain that you can do, hands down.
> Larry
