Roy,
You did the right thing.
There is no single electric fan unit that can pull air through our radiator
like the OEM unit.
We came down to a two fan unit from Spal as the closest, but not close
enough.
To make it work somewhat, one need to have a good fan shroud and even more
higher capacity fan at pressure drop of .60" WG minimum.
> In my book, you need a good fan shroud to utilize as much of the area as
> possible to reduce pressure by spreading out the flow in through the
> radiator.
> We use data from Spal fans as they publish the CFM with the resistance, so
> we have an idea of true flow.
> Free flow data is worthless than a nipple on a Hog.
>> Sounds like very bad publicity for Zeb - just sayin. Why would a GMCer
>> do that to himself - no answer needed!!!
>> I did not know that name before this thread - and now am sure I will
>> forget it immediately - no sense in asking for trouble.
>> BTW - love this group - am learning a lot!
>> Mike/The Corvair a holic
>> Sent from my iPhone
>> > On Apr 10, 2017, at 6:24 AM, Kingsley Coach
>> > Then it's official, it was done at Zebs and for almost $5000....Wow. !
>> > Mike in NS
>> >> On Mon, Apr 10, 2017 at 12:27 AM, Bob Dunahugh
>> >> The fan is a big puller with no shroud. As it's up close to the Rad.
>> Bob
>> >> Barb said it was Zeb, or his son. Aluminum Radiator, fan, belts, 80 amp
>> >> alternator, and some exhaust gaskets. I think that was all she said. At
>> >> close to $5,000. Seems fair. Right? We talked tonight on the plan.
>> Trans is
>> >> going in Thursday/Friday. We all played today. So tomorrow I'm
>> starting at
>> >> the front. Going to check everything till I get to the rear. Then buff
>> the
>> >> paint. And paint the black trim around the windows. I want it to run,
>> and
>> >> look good. Probably be a two week job. She's going to help Linda. So
>> I'm
>> >> going to be on the no labor plan. Bob Dunahugh
>> >> A guy In Georgia put an aluminum radiator in her 73 GMC. Then told her
>> >> that he could put in an electric fan that would be better then the
>> stock
>> >> fan, and shroud. It couldn't pull in enough air to cool the 455 on
>> hills.
>> >> He put in 16 gauge wire. with a 20 amp relay. To protect the wiring.
>> He put
>> >> in a 40 amp fuse. That's a plan. As she was leaving Shawnee. The relay
>> >> fried. So I put the highest amp switch in that I could find. 35 amp.
>> And
>> >> told her to turn the fan on in town, and for hills only to get her
>> the 500
>> >> miles to my house. How the wire held up. I don't know. But it did. She
>> said
>> >> that the switch was getting hot at times. I can't remember the name of
>> the
>> >> guy that ripped her off. It's discussing. Just not right what he
>> charged
>> >> her. Somebody must know his name. Bob Dunahugh
>> >> _______________________________________________
>> >> GMCnet mailing list
>> >> Unsubscribe or Change List Options:
>> > Michael Beaton
>> > 1977 Kingsley 26-11
>> > 1977 Eleganza II 26-3
>> > Antigonish, NS
>> > Life is too short to hold a grudge; slash some tires and call it even !
>> > GMCnet mailing list
>> GMCnet mailing list
> Jim Kanomata
> Applied/GMC, Fremont,CA
> jimk
http://www.appliedgmc.com
> 1-800-752-7502
