Wtb: passenger side "door panel
justin brady1
727
1
I am in need of a passenger side plastic dash panel (the one with the ash tray and cubby) the whole panel.
If anyone has a spare one sitting around or a parts coach with one let me know.
I'm in middle TN but willing to pay for shipping it.
I've got a perfectly good one, but after a botched vinyl attempt the contact cement just won't come off. No amount of solvent or elbow grease will get
it off.
Justin Brady
http://www.thegmcrv.com/
1976 Palm Beach 455
Try "Goof Off" available at most hardware stores - if does not work - I know of a parts coach that may have one.
Mike/The Corvair a holic
Sent from my iPhone
> it off.
> Justin Brady
> 1976 Palm Beach 455
Justin,
I feel your pain, I had 2 failed attempts.
I cleaned the glue with 3M #08984 General Purpose Adhesive Cleaner. It will not damage the part.
Work in small areas , pour some remover, let it soften the glue and paper towel it off.
May need to do it more then once.
Then get the only glue that works
DAP Weldwood Landau Top & Trim
HHR Solvent type UPC # 70798 00233 1 gl size
HHR Solvent type UPC # 70795 00095 5 gl size
High Heat Resistant Solvent Type (HHR) is what you need to look for, then buy a cheap pressure spray gun from HF to spay the glue.
Or pay to have it done, which in some cases, a few peaces, may be less expensive then the materials & tools to do it.
”When we avoid the mistakes we might have made, we sometimes make the mistakes that we might have avoided.”
Adrien & Jenny Genesoto
75 Glenbrook 26-3
Yuba City,Ca. Text 530-nine-3-three-3-nine-nine-6
Check with Chuck Boyd. He may have one on a parts coach. Frank Jenkins makes a fiberglass replacement.
Tom, MS II
1975 GMC Avion
KA4CSG
If you're referring to the the Avion, It's gutted and all the innards are at
my storage facility to support the two I have.
The Pedantic Mechanic
USAussie - Downunder
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Thomas
Phipps
Sent: Wednesday, April 5, 2017 8:48 AM
Subject: Re: [GMCnet] Wtb: passenger side "door panel"
Tom, MS II
1975 GMC Avion
KA4CSG
Have you tried Goof Off and steel wool??
Saturate paper towel with Goof Off and leave it on the panel for a while,
then attack it vigorously with the steel wool.
Worked for us on the panels around the rear window.
RonC
On Tue, 04 Apr 2017 17:55:47 -0600 Justin Brady
writes:
> let me know.
> grease will get
> it off.
> Justin Brady
> 1976 Palm Beach 455
Ron & Linda Clark
North Plains, ORYGUN
1978 Eleganza II
Justin - I know you had mentioned that you were going to have the "door panels" professionally done. Is that who botched the job? What were the
mistakes? I have mine out and I was thinking of taking mine to somebody.
1977 Palm Beach
