ws visor
GOOD POINT! Thanks for the heads-up.
Wayne Newland
> In a message dated 8/4/99 9:11:13 AM Central Daylight Time,
> A word of caution. I used the foil insulation all over the inside and also
> insulated the water pump compartment where I got a little careless. A piece
> of the foil touched an improperly insulated wire and shorted it out. Just be
> sure all wires and connections in the vicinity of the foil are properly
> insulated.
> Justin
How about using some high density foam, Shape it any way you want, Paint it
or cover it with fabric.
Just a thought....
Rob Teed 74 Painted Desert
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto:owner-gmcmotorhome]On Behalf Of Gcbr
> Sent: Wednesday, August 04, 1999 8:14 PM
> To: gmcmotorhome
> Subject: Re: GMC: ws visor
> Richard
> I looked at some at Lowes that was plenty wide enough. If you want to
> get fancy Try a place like Renovators Supply. I dont know if they have a
> web site or not. They got the stuff up to about 12 inches. Any good
> building supply house should be able to order it for you.
> Take Care
> Arch
> In a message dated 8/4/99 6:13:53 PM Central Daylight Time,
> digitek
> > Arch,
> > What did you use to replace the plastic trim you and I both
> > have tossed as no good? I had hoped to use crown molding
> > but it is too narrow by about 1/2 inch (at least the stuff I looked
> > at).
________________________________________________________
NetZero - We believe in a FREE Internet. Shouldn't you?
Get your FREE Internet Access and Email at
http://www.netzero.net/download/index.html
Wayne,
Thanks for that information. I decided that since I am getting low on
funds, time and ideas before my trip Saturday I am going to reuse
part of the 4" OEM plastic trim. I will paint it tomorrow with vinyl
spray paint (same as I did the rest of the trim and the plastic headliner)
and cut the best pieces for the area over the bunk bed couch and over
the door. Inside the lockers it doesn't matter at this point. I just need
to get the coach presentable by Saturday. It is a good thing that my
trim came down relatively easily and thus is in decent shape except for
the yellowing.
Later when time permits I'll go to some other type of trim.
Richard Waters '76 PB, Troy, MI
> Jim
> Another reply told you about the rib running down the middle behind the wide
> moulding. To get it off, take a wide pri-bar that has flat ends. Wrap the end
> of the hook with tape. Slip it under the moulding and gently pry. There are a
> lot of clips that snap into a channel and they might be rusty. Some of these
> will stay in the channel and some will come off with the piece. Take a pair of
> needle-nose plyers and pull out all of the clips, otherwise you won't be able
> to replace the moulding. When replacing, cover a rubber malliot with a thick
> cotton sock and gently pop the clips back into the channel. (Put the clips
> back on the rib before reinstalling)
> Wayne
> > Richard
> > there are alot of us "dummies" out here...me for one...ive got more parts
> > laying around....hope they find there way back on.....started headliner and
> > doing real well until i run up against removing the plastic moulding at
> > ceiling edge....how in hell does that thing come off? if you have a moment
> > tell me how....meantime ill search the archives...thanks jim
The stuff the other guys recommended would be good. That's all I did
was to buy a kit at the local auto parts store. It is really pretty easy. I
made
sure to buy some disposable plastic gloves to work the stuff.
Richard
> Richard,
> I know nothing about working with fiberglass but am willing to try. What
> brand of fiberglass would you recommend me to use to repair those panel you
> described also where to purchase it.
> Many Thanks,
> Ted
> Louisville, Ky
> Palm Beach 76'
> the screw holes were located. I laid some fiberglasss
> over each hole and drilled them out. There were a few
> other minor cracks that I glassed over. After I painted
> the cap and all the other plastic pieces back there (and
> the whole coach I might add).
> I was truly amazed at how good it looks. Just like that stuff
> would have looked right off the assembly line. At this point
> I say go for it and redo all the plastic stuff. Just know when
> to stop as one thing will lead to another with the GMC.
Arch,
Thanks for the tips. I'll save them for later. Right now my plan is
to try and reuse the old trim. I've run out of time and money for anything
better. The old trim is really not in that bad of shape, except for the
yellowing. I'm going to paint it, stick it up and then do something else later
when I have more time.
Richard
> Richard
> Take Care
> Arch
> In a message dated 8/4/99 6:13:53 PM Central Daylight Time, digitek
> > Arch,
> > at).
