Wire raceway covers
RF_Burns
Super Moderator
Staff member
Sep 7, 2008
5,182
1,378
113
Ontario Canada
Many have asked in the past about replacing the covers for the wire raceways along the top inside of the coach. Instead of installing a new plastic
style cover, A PO used stained walnut wood baseboard.
I finally posted some photos becauseI think it looks nice.
http://www.gmcmhphotos.com/photos/misc/p62441-wire-race-cover.html
http://www.gmcmhphotos.com/photos/misc/p62442-wire-race-cover.html
Bruce Hislop
ON Canada
Hubler 1 ton front end
The wood raceway does look great - is it attached with screws, or some kind of track, clip, etc?
I also like the ceiling color/texture. Is that fabric on a wood or plastic base?
Raleigh, NC
The oak baseboard cover is attached in 3 places each side with black anodized counter sunk screws. You need to look for them to see them.
The ceiling was also update by the PO. It is a thin (1/8") lauan type wood covered with fabric. I'm not sure what the fabric is called, but I've seen
it in custom vans. Its also down the walls to the bottom of the windows. Below that its a thin plywood with a stained oak (I'm guessing) veneer.
Bruce Hislop
ON Canada
I used leftover laminate flooring to cover mine.
I drilled and tapped the aluminum, cut short pieces of 1/4" threaded rod, and used acorn nuts to hold it on.
Easy access afterwards too.
