At the risk of rekindling past tire wars, I have found that tires replaced
while still young more readily get away with being cheap. I've been using
whatever inexpensive polyester-sidewall tires my tire guy has been able to
find. The last set was Load Range E only because they were cheaper than the
Load Range D alternatives. They are four years old and I'll replace them
year after next.
I also inflate them strictly per manufacturer recommendations, which
depends on load. For my very light early 23' coach, I use 65 psi in the
front and 45-50 psi in the back.
I've had one flat caused by a nail, but no other tire issues.
I think my last set cost about $750 mounted, but I removed and replaced the
wheels myself.
Now, the tires on my beater pickups, well, let's not talk about those.
Rick "knocking on wood" Denney
> ok Ken, agree... ok I am Sam's member, what is best recommended tires for
> $$$ value these days?
> thx Mike
> On Mon, Oct 9, 2017 at 11:19 AM, Ken Henderson
> > Mike,
> > Just remember: If one of those "little sidewall fine lines" decides, as
> > they often do, to let all the air out instantaneously, you'll probably
> have
> > a $2000+ fiberglass repair bill.
> > Ken H.
> > > Hello All... been awhile Mike Derr from Madison WI here...
> > > 78' I have original wipers, bought replacement rubbers... not sure how
> to
> > > reassemble, I see those metal u-shapped 1" clips... then holes for a
> > bolt?
> > > pin?
> > > I googled to see a assemble help but was not able to find any.
> > > thanks all.
> > > Mike
> > > PS: we are planning a lil trip Wed. to Door County here...
> > > Pss: kinda have older tires good tread, but little sidewall fine
> lines,
> > I
> > > feel should be ok though.
> > > _______________________________________________
> > > GMCnet mailing list
> > > Unsubscribe or Change List Options:
Rick Denney
73 x-Glacier 230 "Jaws"
