Windshield wipers actuator bracket replacement
shan rose
827
A couple years ago my coach was vandalized by a couple f@#kheads and they literally broke the passenger side wiper arm clean off snapping the stud
that it mounts to. Now granted it doesnt rain much here in soCal but I would like to fix this. Is it possible to install a new stud in the old bracket
or will the whole thing require replacement? I'm assuming that bracket was used on other GM vans of the same period so maybe it is possible to source
one from them? Any help is appreciated as always.
Shan
Shan,
I'm pretty sure the entire stud bracket, and the attached linkage are
attached to the underside of the horizontal portion of the firewall just
below the windshield -- 2 or 3 vertical hex headed bolts, 1/2" or 9/16".
It's very unlikely that you'll get a replacement anywhere except from a
junked GMC, but that should be pretty easy to find since few of them are
replaced. Someone here may volunteer to help, or you can call one of our
usual suppliers. If your signature block included more information, like
coach model and your city, we might guide you to closest support.
> bracket
> Shan
ok fixed. :) I'll remove the linkage later and see if I can get a P/N off of it...
73 Canyon Lands, (a.k.a. The Yellow Submarine) West Los Angeles CA
If MIguel has a parts coach around, it will almost certainly have that part
on it. It's not likely to show a part number and it won't mean anything to
anyone anyway.
> of it...
I recently had to replace that wiper arm and linkage due to a heavy snow
fall that broke the wiper stud. Two 5/16" bolts hold the bracket to the
cowling and three 10-32 bolts hold arm to that bracket. I was able to
force the old linkage out but because of the heater box I had to remove the
thee 10-32 screws to install the linkage arm. Not much room under there to
get at screws.
On Tue, Jul 25, 2017 at 8:32 PM, Ken Henderson
> anyone anyway.
> Ken H.
> > of it...
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
so is it the whole linkage that has to be replaced or can simply the stud be replaced?
I did not see how it could.
Hope you saved the knurled insert!
> be replaced?
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
thats what I need a new pivot shaft....
You have 2 electric wiper motors? One on each side?.?
C. Boyd
76 Crestmont
East Tennessee
You can call our order desk and get a quote for new or used.
http://www.appliedgmc.com
