windscreen washers
boybach
1,071
224
63
Worked up till recently, thinking Iight have disloged something when I was in the dash looking at the fuel gauge connectors, but also possible I've blown a fuse ..does anyone know what fuse I should check ?
Disconnected pump and impulsed washer switch with voltmeter connected to the disconnected terminals at the washer bottle - got 12v.
Connected battery power to the washer pump - pump didnt run.
Ordered this washer bottle/pump from Amazon.
https://www.amazon.ca/dp/B07JMBYP64?
Will install tomorrow.
Reactions: Tybalt39
I bought basically the same thing (different "brand", similar kit). Works fine! The purists will say it should have a top straw instead of a bottom feed, but it works. :)
Amazon US link
I already replaced the OEM with a Chev tank from the junkyard a few years back and it was a bottom feed also. Worked fine up until this week too.
