OK, I know this has been asked before....
I need the Window track stuff ( Felt In Think ).
My old windows had metal spring looking stuff???
I need enough for cab windows, Two Living area
windows ( Large ) and Two bedroom Windows (small).
Also, Im trying to stop leaks...Pulled one of the
bedroom windows out. Tried putting waterproof
weather strip ( Stuff used for Pickup bed liners )
on then reinstalled the window. The screws on the
window retaining bracket striped out before the
window got a tight seal....Should I use bigger diamiter
screws???? I thought about silly-cone, but I
think its too hard to remove windows after that.
I need a paintjob in the spring so thinking ahead. I
pulled one of the metal dripedges off the exterior
seam. What a mess! The foam had disintegrated. I
Broke a screw off. Do I remove it or just put one
beside it? What was the material used on that seam.
Looked alot like bondo...Was really pliable.
Thanks,
Rob Teed
Thanks,
Rob Teed
