Wind wings
A better choice is Blaine Merrell who makes them in assorted colors and all stainless hardware. It is a simple 2 screw installation.
Thank you for the tip.
Ragusa has them. They work nice.
Two things I learned with my wind wings. Buy some extra screws and keep the allen key handy. The bottom screw is facing down and gravity causes it to fall out. You need it tight to not vibrate, but you dont want too tight or you will crack the plastic when you try to adjust it.
I set mine and forget it now.
Wonder if some blue stay tight or a dab of silicone would help keep it in place?
Well, I talked to him for around 45 minutes. You are correct. He does not wanr to make them any more. He also said he no longer wants to make trailer hitches, but he has a few used ones around that he might part with. Bead blast them and repaint them and they would be just like new. There is nothing on a hitch to wear out so that would work just fine.
