Wide Dish Alcoa
marcus mcgee
809
O'boy another post about Acoa Wheels!!!!!!!
In this months GMCMM Jin Anstett writes about test driving a fellow
GMC'ers coach with "WIDE DISH" Alcoas on the front. After saying it
drove beyond belief over the large ruts on an interstate, he goes on to
say that it is problematic with the bearings, steering gear etc.
Ok, I agree on all the loading problems, but "I WANT WIDER WHEELS ON MY
COACH". I know its wrong so don't yell at me. I want them and they
look good filling that empty wheel well.
OK, so what is the # of the forbiiden wheel? Jim did not say in his
article.
Marcus
You should consider the problems they are going to cause. If for some
reason you lose air in the back or have a soft tire, you can almost
guarantee that you will lose an airbag, and maybe more. The coach was
designed to use 8.75 tires and anything larger will cause interference
problems at certain times I talked to people at cinnabar a short time ago
with the same plan to put larger tires on my coach,since I plan to replace
the 16.5 tires with 16" ones anyway. They very strongly were against the
larger tires.
>article.
>Marcus
I want them on the front, not the rear. Well, aybe when I see them I'll
change my mind.
Marcus
> larger tires.
> >article.
> >Marcus
Marcus:
Despite the dire predictions of front wheel bearing failure you always
hear whenever someone mentions using a wheel with less offset than
recommended, I'm not sure people have a valid argument. Mostly, I
believe, they are parroting what they have heard from someone else.
I'm aware of three coaches running the wider wheels without apparent
bearing difficulty.
The comments you attribute to Jim Anstett, I believe, pertain to a coach
that I'm told attended the GMCMI Las Vegas Rally. The owner, who lives
in CA, I understand hired a competent engineer to calculate the loads
associated with the wide wheels vs. the original. Supposedly, the loads
were more favorable when the wide set wheels are used. Would like to
see the calculations, however.
I'm also told that a GMC Dixelanders coach owner, from TN, has been
running the wide wheels for many years. Allegedly, he's not done any
bearing replacement and has worn out a Jasper engine in the meantime.
Jack Burke, from Mentone IN, also runs the wide wheels.
In spite of the supposed negatives in doing so, is anyone aware of
disastrous results in running wide set wheels? I'm not.
Reaction to the above should be interesting.
Paul Bartz
> -----Original Message-----
> From: Marcus McGee [SMTP:crsalert]
> Sent: Wednesday, April 29, 1998 5:06 PM
> To: gmcmotorhome
> Subject: Re: GMC: Wide Dish Alcoa
> I want them on the front, not the rear. Well, maybe when I see them
> I'll change my mind.
> Marcus
> problems at certain times. I talked to people at Cinnabar a short
> time ago with the same plan to put larger tires on my coach,since I
> plan to replace the 16.5 tires with 16" ones anyway. They very
> strongly were against the larger tires.
> to say that it is problematic with the bearings, steering gear etc.
> MY COACH". I know its wrong so don't yell at me. I want them and
> they look good filling that empty wheel well.
> article.
> Marcus
Marcus:
Forgot to mention that the CA owner is supposedly running an Alcoa wheel
normally used on late model Ford dually trucks. I believe that since
that wheel does not use the piloted feature of the hub, that a thin
spacer is needed.
You may want to contact Jim Anstett to get the CA coach owners name and
talk to him about the details.
Paul
> From: Bartz, Paul
> Sent: Thursday, April 30, 1998 9:35 AM
> To: 'gmcmotorhome'
> Subject: RE: GMC: Wide Dish Alcoa
> Marcus:
> bearing difficulty.
> coach that I'm told attended the GMCMI Las Vegas Rally. The owner,
> who lives in CA, I understand hired a competent engineer to calculate
> the loads associated with the wide wheels vs. the original.
> Supposedly, the loads were more favorable when the wide set wheels are
> used. Would like to see the calculations, however.
> Paul Bartz
> To: gmcmotorhome
> Marcus
> article.
> Marcus
I wonder what the large tire chain dealers have to say about it and how
filtered their opinions are???
Paul Bartz
> From: CHill113 [SMTP:CHill113]
> Sent: Thursday, April 30, 1998 12:13 PM
> To: gmcmotorhome
> Paul
> I've always heard the story about bearing problems too. However I see
> A LOT
> of pickups and cars driven by the younger set who have very wide
> wheels.
> Perhaps checking with someone on how much bearing trouble these
> vehicles have
> had would give us a clue!
Going a little wider shouldn't have much effect on the bearings unless
the offset is wrong.
Remember, if you were to move from a 7 inch wheel to an 8 inch wheel,
the new wheel could protrude out 1 inch, or 1/2 inch, or not at all,
depending on the offset.
On one of my cars, I am able to get an 8" wheel up front where others
can only use a 7, because I found a wheel where the extra inch was
compensated for by a change in offset.
Bob Brewer
- -----Original Message-----
Sent: Thursday, April 30, 1998 9:24 AM
To: 'gmcmotorhome'
Paul Bartz
> To: gmcmotorhome
> Paul
> A LOT
> wheels.
> vehicles have
Bob:
If I'm not mistaken, a change in the offset is what it will take to get
the front wheel width to match with the rear wheels and not the tire
width.
Paul Bartz
> From: Brewer, Bob [SMTP:rebrewer]
> Sent: Thursday, April 30, 1998 12:33 PM
> Bob Brewer
> From: Bartz, Paul [mailto:s9d3452]
> how
> Paul Bartz
> > Paul
> see
> > A LOT
> > wheels.
> > vehicles have
Sent: Thursday, April 30, 1998 9:41 AM
To: 'gmcmotorhome'
Bob:
width.
Paul Bartz
> Bob Brewer
> how
> Paul Bartz
> > Paul
> see
> > A LOT
> > wheels.
> > vehicles have
Paul,
Sort of. It has more to do with track width at the front. The concern
here seems to be with presenting the wheel bearings with additional load
due to a wider width wheel sticking out more than stock. The offset
(from center) or the other commonly used measurement, backspacing, will
determine what length "lever arm" the bearing will see.
Unless, of course, I've completely missed the point!
Regards,
Bob
To: 'gmcmotorhome'
Bob:
width.
Paul Bartz
> Bob Brewer
> how
> Paul Bartz
> > Paul
> see
> > A LOT
> > wheels.
> > vehicles have
Bob, et al:
What we really need to do is identify the CA coach owner who I mentioned
was at the GMCMI Las Vegas Rally and get him to share the engineering
data/calculations on the front wheel bearings he obtained. Anyone know
the name of whom I speak of?
Paul Bartz
> Sent: Thursday, April 30, 1998 12:56 PM
> To: 'gmcmotorhome'
> Paul,
> concern
> load
> will
> Regards,
> Bob
> To: 'gmcmotorhome'
> Bob:
> get
> width.
> Paul Bartz
> unless
> wheel,
> others
> > Bob Brewer
> > how
> > Paul Bartz
> > > Paul
> > see
> > > A LOT
> > > wheels.
> > > vehicles have
