Why was GMC setup to ride low in the rear?
robert mueller
17,586
G'day,
I'm still trying to figure out why the GMC was setup with the rear end lower
than the front. Why didn't they set it up level?
It has been suggested that:
1) To get more caster
Comment: GMC could have located the mounting tabs for the upper and lower
control arms wherever they wanted to position the upper and lower ball
joints to get whatever caster they wanted; why would the locate them to
require running with the rear lower?
2) To make the fuel run into the rear tank
Comment: Quite possibly
3) Front to rear weight balance
Comment: GAWR = 4,500 lbs Front Wheels
GAWR = 8,000 lbs Rear Wheels
Comment: Running the GMC with the rear lower than the front would increase
the weight carried on the rear would it not? Why not run the GMC level?
4) Angle of attack (AoA)
Comment: I wonder how much having the rear end lower by 1 7/16" as measured
at the height measurement slots would affect AoA.
I took some more measurements the other day when I was at the workshop.
Here's a summary of all I have:
1) 13 1/8" = front ride height setting at 0" tolerance
2) 11 11/16" = rear ride height setting at 0" tolerance
3) 1 7/16" = front to rear drop at center of slots at 0" tolerance
4) 24 3/8" = center of front height adjustment slot to front axle center
5) 160" = center of the front axle to the center of the two rear wheels
(wheelbase)
6) 56 3/8" = center of rear height adjustment slot to the center of the two
rear wheels
7) 240 3/4" distance between center of front and rear adjustment slots (24
3/8" + 160" + 56 3/8")
8) 274" = end to end length of chrome trim piece on 1975 GMC Avion
9) 46 1/2" = distance from the center of the front ride height slot to the
front end of the beltline chrome trim piece
10) 34" = distance from the center of the rear ride height slot to the rear
I can take the measurements but my math skills are not good enough anymore
to figger the following out:
A) Using the measurements above what is the angle of the drop front to rear?
B) Using the measurements above what is the measurement of the drop at the
ends of the chrome trim piece?
It has been noted that with the front and rear ride height set as above the
front axles are straight and level with the ground with 225/75-16R tires
fitted.
I'm not sure but I think it has also been noted here that with the front and
rear ride height set correctly you can draw a straight line through the
center of the middle axle - front bogie pivot point - rear bogie pivot point
- rear axle; is that correct? I can't check it myself as The Blue Streak is
up on jack stands.
If anything I have stated is incorrect, illogical or my math incorrect
PLEASE correct it!
Regards,
Rob M.
By my math,
A is 0.3421 degrees
B is 1.636 inches
Because, arctan(1.4375/240.75) = 0.3421 deg
And, tan(x/274) = 0.3421 deg, x = 1.636 in
1973 Sequoia 260 (since 2011)
In-transit, westward
Rob,
I've ponder this before as well.
- I also don't think it has anything to do with caster. Thanks for measuring the distance from the center of the bogie to the rear height adjust. That means the radius from the front axle is actually 160+56 = 216" so ~ 1/4° per inch of ride height adjustment.
- Gas tank... The gas tanks sit side by side so the 1 7/16" difference over 216" isn't going to amount to much over the say 48" between the tanks (3/10") inch.
- Weight radio... Again 1 7/16" difference isn't going to shift any meaning amount of weight.
- Angle of attack?? I know AoA as it applies to airplanes but I don't see where this would make any difference on the GMC.
One thing I was wondering about was the position of the rear bogie arms with relationship to the bogie arm pivot point. Raising the rear would put the pivot point above the bogie arm axle. The forces on the front bogie arm would cause it to tend to lift the back just as in braking? especially goving over potholes... Maybe.. maybe not...
Or maybe they thought it looked cool...
or maybe someone made an error in the specs and no one questioned it!
Bruce Hislop,
S. Ontario Canada
77PB, 455 Dick P. rebuilt, DynamicEFI EBL EFI and ESC.
Hubler front end installed and WOW! !:)
Geese Rob...and I thought "I" needed to get a life...;)
> G'day,
> (wheelbase)
> rear wheels
> fitted.
> up on jack stands.
> PLEASE correct it!
> Regards,
> Rob M.
> http://temp.gmcnet.org/cgi-bin/mailman/listinfo/gmclist
Larry :)
78 Royale w/500 Caddy
Menomonie, WI.
I recently adjusted my ride height to the factory specs, both front and back.
The rear air system always adjusts the rear height based on load weight and it
sets it dead nuts to spec.
The rear is a tad lower, but not much in my opinion. I know it was designed
that way for handling and steering, but I think the rear being a little lower
gives the coach a nice good soft look too.
Pix link attached.
http://tinyurl.com/3rwm3oe
Ray
Ray & Lisa Erspamer
78 Royale "Great Lakes Eagle"
Center Kitchen TZE368V101144
Wauwatosa, Wisconsin 53226
Email: 78GMC-Royale
414-745-3188
Web Site: http://ray-lisa.page.tl/
----- Original Message ----
Sent: Thu, August 18, 2011 7:48:19 AM
Subject: Re: [GMCnet] Why was GMC setup to ride low in the rear?
By my math,
A is 0.3421 degrees
B is 1.636 inches
> G'day,
> (wheelbase)
> rear wheels
> fitted.
> up on jack stands.
> PLEASE correct it!
> Regards,
> Rob M.
Sir Rob: The dimensional drawings gives an approach angle of 20* and a departure angle of 12* for both the 23 & 26. Don`t know if this wiould apply to your calculations or not.
http://www.bdub.net/GMCdrawings/
C. Boyd
76 Crestmont by Midas
East Tennessee
Its low in the back so all the water that leaks in through the roof runs out the back. :)
Sully
77 royale
Sent from my Verizon Wireless BlackBerry
-----Original Message-----
Sender: gmclist-bounces
Date: Thu, 18 Aug 2011 07:15:10
To:
Reply-To: gmclist
Pix link attached.
Ray
Ray & Lisa Erspamer
Email: 78GMC-Royale
414-745-3188
By my math,
A is 0.3421 degrees
B is 1.636 inches
Bruce,
I just looked at MM X-7525 Page 3A-20 Fig. 31 - Vehicle Ride Height and
you're right, I Screwed it up!
I figger'd I would that's why I asked to be corrected!
THANKS!
Rob M.
I think Item 7 should be 160 + 56 3/8 - 24 3/8 = 192"
Just cause we are getting so exact here!
Bruce
Most are way too low because too many folks just ignore the air system and guess what, in an air system, when pressure goes down so does the ride height. Probably the most neglected part of the coach is the air system and bags.
Phil Swanson
Larry,
Good point! ;-)
Regards,
Rob M.
Sydney, Australia
AUS '75 Avion-The Blue Streak TZE365V100428
USA '75 Avion-Double Trouble TZE365V100426
Larry
Chuck,
I don't think so, but thanks for reminding me that those drawings exist,
they may come in handy for the purposes of figger'n this out.
I looked them over carefully but there aren't any measurements from the
ground up to the frame or axle centers as far as I can see.
Regards,
Rob M.
[mailto:gmclist-bounces] On Behalf Of Charles Boyd
C. Boyd
The way I check or adjust my ride height is this....
The first time I had the coach in the position per X-7525 Page 3A-20 Fig. 31, I
then cut some 2"x2" hard maple blocks that fit between the road and the bottom
of the frame at a defined location. Then whenever I want to check it or make
adjustments, I can do it very easily and quick by sliding the block under the
frame. No messing with a tape measure, etc.
Ray
Ray & Lisa Erspamer
Email: 78GMC-Royale
414-745-3188
Sent: Thu, August 18, 2011 10:37:22 AM
Bruce,
THANKS!
Rob M.
Bruce
How do you measure the left side rear? My generator is right where the oval hole should be. I have been measuring the bogy mount on the right and making the left the same.
Mark
Mark Grueninger 76 Palm Beach
Valmeyer IL
Well, that changes everything..! :)
A is 0.429 deg
B is 2.05 in
I assumed the ride height design had something to do with the differing front/rear suspension system behaviors, and trying to prevent too much frame racking by putting as much of the compensation into the rear as possible without creating a excessively weird ride for humans.
Set right rear then measure from bottom of rt rear rail to floor and use that number for right same point bottom of rail (that's what I was told by this group)
Sully
77 royale
------Original Message------
ReplyTo: gmclist
Sent: Aug 18, 2011 9:03 AM
Mark
Valmeyer IL
Another consideration... it was just style, combined with after the fact
engineering to improve steering. Style of 1977 was low in the rear...
All brochures from the time even were taken to exaggerate the high in the
front stance.
http://oldcarbrochures.org/index.php/NA/Chevrolet_Corvette/1977_Chevrolet_Corvette/1977_Corvette_Brochure/1977-Chevrolet-Corvette-02-03
http://www.heatercorereplacement.com/index.php/models/chevrolet/chevrolet-camaro-1977/
On Thu, Aug 18, 2011 at 1:19 AM, Rob Mueller wrote:
> G'day,
> lower
> (wheelbase)
> rear wheels
> rear?
> fitted.
> and
> point
> up on jack stands.
> PLEASE correct it!
> Regards,
> Rob M.
I think you missed one. This allow two BIG people to sit up front and the coach will level out. If they sit in the rear the airbags automatically adjust. If thet sit up front front the coach rides a little lower.
But, Ken, our obesity epidemic hadn't started back then!
