If you put 2" wheel spacers on a stock GMC front end, it will also torque
steer. I have done that very thing on my coach, and installed another set
on a different coach, with the same results. Torque steer that will yank
the steering wheel out of your grip.
So, I do not equate torque steer with the 1-ton, but with front wheel
drive vehicles. I have a P.T. Dream Cruiser that has 220 horsepower in it's
turbocharged 2.4 L. engine. It weighs just over 2000 pounds, and is a real
rocket ship. If you turn the front wheels slightly and turn the traction
control off, it becomes a real handful if you jump on the throttle. I have
torn out the engine mounts twice doing stupid stuff like burnouts with it.
So, front wheel drives with surplus torque are more guilty than the 1-ton
in my opinion. But, opinions vary.
Salem, Oregon
On Fri, Jan 22, 2021, 7:37 PM Zandr Milewski via Gmclist <
> Jim-
> At first approximation, no argument. These are six-ton beasts, and you
> have to scale your expectations accordingly.
> On the other hand, if we can understand the suspension geometry at play,
> we can make the best of our lot. Certainly, the concerns about scrub
> radius have a basis in minimizing torque steer. The "non-parallel
> control arms" question is more interesting, as that relates to camber
> gain, and depending on other factors, bump steer.
> Zero camber gain is not always the answer. The only doc I've seen with a
> discussion of suspension geometry didn't really understand how it
> worked, as it concluded incorrectly that every one-ton coach should be
> sitting on the bump stops.
> -Zandr
> > The GMC Motorhome is NOT a performance vehicle. It wallows in tight
> curves,
> > barely stays straight on good roads. It is at least 40 years old, and
> > designed around parts plucked from production lines of various
> automobiles
> > of the era. Nothing state of the art about the suspension and drive
> train.
> > It does a fair job of point to point transportation of a heavy
> vehicle
> > that has a great deal of its weight centered above the tops of the tires.
> > A race car, it definitely is NOT! If you do not expect sports car
> > handling, and maintain the drive train/suspension parts well, it is safe
> > enough to drive in traffic if you don't follow too closely and drive
> "eyes
> > way down the road ahead", you won't get in too much trouble.
> > There are upgrades that improve braking quite a bit, and that is
> one
> > huge reason for the 1-ton conversion. That and much stronger lower
> control
> > arms and front wheel bearings as well as upper and lower ball joints.
> > Handling? Very subjective at best. It still is a top heavy front wheel
> > drive vehicle. Not much will ever change those facts.
> > Do I love them? Yep! But, don't put lipstick on them. Underneath,
> they
> > are still a very good looking
pig.(grin)
> > Jim Hupy
> > Salem, Oregon
> > On Fri, Jan 22, 2021, 4:55 PM Joe Weir via Gmclist <
> gmclist>
> >> Yes, My bad. The point was that while not completely fixing the issue,
> >> it certainly moves it closer to correct.
> >>>> Also moving tire inboard may be able to fix the steering axis or
> some
> >> of the error, but not sure that totally fixes scrub radius.
> >>> Scrub radius is literally defined as the distance between the center of
> >>> the contact patch and the point where the steering axis touches the
> >> ground.
> >>> _______________________________________________
> >>> GMCnet mailing list
> >>> Unsubscribe or Change List Options:
> >> 76 Birchaven - "Wicked Mistress" - New engine, trans, alum radiator,
> >> brakes, Sully airbags, fuel lines, seats, adult beverage center... those
> >> Coachmen
> >> guys were really thinking about us second hand owners by including that
> >> beverage center...
> >> Columbia, SC.
> >> GMCnet mailing list
