Why do we still measure ride height to the frame slots?
RF_Burns
Super Moderator
Staff member
Sep 7, 2008
5,151
1,354
113
Ontario Canada
So, my thinking is the slots were used in production, but are not the greatest idea in the real world now.
The rear slots are several feet behind the bogie, which is the suspension point of the rear wheels. Unless you are checking the ride height on a
perfectly flat level piece of concrete, you could have severe errors in your measurement. Not to mention you can't access the slot under the
generator anyway.
I measure from the ground to the bogie Zerks. This is the pivot point for the rear suspension and mid-way between the two rear wheels. At this point
the rear measurement is not affected by the front height or need to be level surface front to back. Also the area between the two wheels is most
likely to be reasonably flat if not on a concrete surface.
I believe the measurement is 13.25" on my coach to the Zerks.
I know some measure to the top of the rear wheel-wells. I believe this measurement can introduce some errors and uncertanties as well. That
measurement is on the body, not to the frame. The body is sitting on rubber pads and the weights and distributions can change significantly with
fresh and black water quantities and also propane load introducing some amounts of errors.
What say yeh?
Just my farm-boy mechanic way of seeing things.
Bruce Hislop
ON Canada
Also, forgot to mention the tetter-totter effect. The rear slots are nearly 5 feet behind the bogies, which are the pivot point for the rear
suspension. So if the front wheels are not level with the rear wheels, the rear measurement will be thrown out. Also, if you are doing a height
adjustment, you do the back first then the front. If you had to adjust the fronts, then the rear needs to be adjusted again because the measurement
has changed. If it was adjusted using an accepted measurement to the Zerks, the measurement should not change.
Bruce Hislop
ON Canada
Bruce,
I agree with you about measuring from the bogey box location for the reasons you mentioned, but the isolation pads aren't a short term factor and is a
very low order variable.
Back of the phone calculation:
Worst case scenario of variable weight on the body of liquids/propane
~1000# (that's totally empty to totally full which rarely happens if the coach is in service)
Isolation pad area
6x3"x3" (pads on back half of coach only)
54 in2
So ~20psi delta from variable liquid loads
The ride height measurement spec is +/- 1/4" and I'd be surprised if the pads compressed more than 1/16" with the change in load from full to empty.
Measuring to the belt line won't throw off the validity.
Richard
'77 Birchaven TZE...777;
‘76 Edgemonte
In my vast collection of nearly useless information is the fact that I am a distant relation to Christian von Nagel.
In case you don't recognize that name, he wrote an early 19th century treatise on the effects of experimental error. In this, he allowed that there
are often unknown variables (like the front ride height) that, if can be maintained as stable (even if you don't know they exsist), will not effect
the validity of the result. Unfortunately, this was in later years translated as "Finnagle" and intended to mean you can do what ever you want to get
the answer that suits.
Why does this apply?
Because as long as Bruce measures his rear ride height the same way, his result will be valid. This is also very true as most coaches have the rear
registry point hidden by the generator mount.
