White Knuckle ride
steven d. ferguson
874
my G159s are at 60 lbs front and 55 back, or sometimes 65 front and
60 back... anyway, that's what I was told to use and you might scale
back the
pressure and see if it helps.
Pretty much the same here. I tried 80lbs & hated the results. Went to
70lbs all the way around & it helped mucho. BTW, All of my front end
components are new and I just had a 6 wheel alignment. G159's with new
Bilsteins. Just what I did and it worked for me.
Steve F.
Ditto hating the ride at 80lbs.
I'm back to 65 lb range... for good.
Heinz
> back the
> Steve F.
I may be mistaken, but if you have Load Range E tires and only fill
them up to the Load Range D pressure, what is the point in buying Load
Range E? At 65psi, they can carry no more than a D load safely anyway.
Last I knew, less pressure causes increased sidewall flex, which
increases tire heat, which causes tire failure. And if you say you are
NOT overloading the tires, then why waste money on Load Range E tires?
I'm no tire engineer, but I feel I missed something here.
The Load Range C tires on my 6000 pound 16' Class C call for max
capacity of 1735 lbs each at 50psi, so 55-65 for Es sounds awfully low
to me.
- ----- original message -----
Date: Tue, 01 Feb 2000 11:08:58 -0800
Subject: Re: GMC: White Knuckle ride
Heinz
> back the
to
new
> Steve F.
Virus or hoax? http://www.symantec.com/avcenter/hoax.html
E-mail tax? Kidney harvesters? http://www.urbanlegends.com
Free internet and POP3 e-mail: http://www.netzero.net
Join the fight against SPAM: http://www.cauce.org
Visit http://www.alladvantage.com/go.asp?refid=IYT537 and get paid to surf the web.
Visit my personal website: http://www.geocities.com/a62dave
Do You Yahoo!?
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
