Jess, Larry, Steve and anybody else.
Detroit puts the engine temperature sensor in the water out because that is what will best indicate an overheat condition. The thermostat is there
for another very simple reason - Cost. If you really want to regulate an engine's operating temperature, you need to control the temperature of the
coolant entering the system. If you look at the high-buck engines you will see the thermostat is not in the coolant out.
If one really wants to know what is happening, you want to watch both sides of the coolant. The coolant in temperature will tell if your cooling
system is capable at current loads. If that goes up, the only answer is that you have a big problem coming unless you can unload the engine. With
the coolant in controlled, the coolant leaving the engine will be responsive to the actual engine condition.
Why have I not moved my control to the coolant in side when I have a control to do it waiting on the shelf??
Very simple, I installed the new fan and very soon after that a piston shed some rings and I had to take the engine out. Then in the spring of the
next year we had a problem with a lower control arm that has kept the coach on light duty for the next year. I have to have the coach up and running
for a time with some added instrumentation to determine what I want for a coolant in temperature. That will take a day's highway run to calibrate the
fan control, and that is after I install two thermocouples that I trust. When I know that value, then I can tell others. Fortunately, when I have
determined a good set point for coolant in, that will be true for virtually all 455 coaches (regardless of the radiator installed) and may also be
good for 403 and 500. It will also make the optimal ignition timing more stable.
