I know this has been debated numerous times but I am about to get new wheels and tires for our coach. I currently have 16.5 weld wheels and aged out
Michelins. I plan on going with Michelin Defender Ltx tires (too much bad luck with off brand tires to ever try that again). I am debating wheels,
Thanks to the forum, I understand the factory wheels are hub centered, the 16.5s are all but obsolete and currently 16 in wheels are the preferred
choice. That leaves the hub centered eagles or a set of no longer in production but correct Alcoas. Other options are use a lug centered wheel in 16
or 17 inches, and confirm that they will clear the calipers and have the correct offset. The coach has run lug centered wheels since 1998 with no
apparent ill effects. I plan on keeping this coach till I can't drive anymore (hopefully at least 20 more years
and I don't want to have to
purchase wheels again in 5 years because I can't find decent tires. So, any info out there to help me make the right call?
JD Lisenby- USAF Ret
1978 Royale-455
Electromotive Tec2 FI & ignition
Navarre, FL
1978 Royale-455
Navarre, FL
