Wheel Knock
voyager
155
I drove the coach around the block. There seems to
be a " Knock " in the left front wheel. The
brake rotors are quite rusted on the surface...
could this be the cause? It makes the stearing
wheel shake abit.
Rob Teed 74 Painted Desert
Hi Emery,
I fear that it will be a wheel bearing. I just
did the brakes on my dodge ram. WHAT a pain! Took
almost 10 hrs. Couldnt get the rotors off.
Guess I'll get the manual out and see whats
involved in replacing or repacking the wheel
bearings. I'll also check the brakes.
See Ya,
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto:owner-gmcmotorhome]On Behalf Of
> EMERYSTORA
> Sent: Tuesday, April 20, 1999 12:25 AM
> To: gmcmotorhome
> Subject: Re: GMC: Re:Wheel Knock
> wheel shake abit.
> Rob -- first pull the hubcap from the front wheels. Often one
> will give a
> "knock" sound especially at low speeds. The brake rotors often
> get rusted if
> the motorhome is sitting for a while. After you apply the brakes
> the brake
> pads will scour them off. The steering wheel shaking could mean that the
> pads are gripping erratically. It could be caused by dirt or
> rust. Take it
> for a longer drive and hit the brakes a few times and see if it
> goes away.
> If it doesn't you better pull the front wheels and check out the
> rotors and
> brake pads. The symptoms could also be a wheel bearing going bad. This
> would give a noise and could cause a wheel shimmy.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
Sometimes a tire that sits with weight on it in one position will get a bit
of a flat spot. I'd describe the result as a thump. If this is the case the
thump should go away after a while fo driving.
The
> wheel shake abit.
Once per revolution? If so and it's not a metallic sound, you might drive a
bit at low speed to see if the problem is caused by a flat spot. Also,
check to make certain that your wheels are centered on the hub.
Henry
Soquel, Ca 95073 / IP reviews
fax: (831) 462-5198
If you are just taking it out of storage and it did not have the knock
before you stored it, its not the bearing. caliper is probably seized.
>Hi Emery,
> See Ya,
>> EMERYSTORA
>> To: gmcmotorhome
>> wheel shake abit.
>> will give a
>> get rusted if
>> the brake
>> rust. Take it
>> goes away.
>> rotors and
>> Emery Stora
>> 77 Kingsley
>> Santa Fe, NM
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Hi Henry,
I'm going to pull the rotors off, get them turned
replace the pads. Check the wheel bearings.
Thats what I'm going to do.I have an autozone
nearby. What parts might I need to do this job?
Anyone have the part numbers?
Thanks,
> [mailto:owner-gmcmotorhome]On Behalf Of Henry Davis
> Sent: Tuesday, April 20, 1999 1:25 AM
> To: gmcmotorhome
> Subject: Re:GMC: Wheel Knock
> get a bit
> the case the
> The
> > wheel shake abit.
> might drive a
> Henry
> fax: (831) 462-5198
> replace the pads.
Rob,
Don't turn the rotors unless they really need it. Those puppies are
expensive and unless they're seriously grooved, let 'em be.
My $.02,
Patrick
Patrick Flowers
Mailto:patrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
OK, Thanks for the tip. I think there just
real rusty.
> [mailto:owner-gmcmotorhome]On Behalf Of Patrick Flowers
> Sent: Tuesday, April 20, 1999 8:40 PM
> To: gmcmotorhome
> Subject: Re: GMC: Wheel Knock
> > replace the pads.
> Rob,
> My $.02,
> Patrick
> Patrick Flowers
> Mailto:patrick
>Hi Henry,
If you check them you may want to replace them. I my conversations with the
Timkin engineers it's become pretty clear that fingerprints and dirt can
seriously decrease the bearing life. So, I replace the bearings whenver
they "need" to be inspected. I know that I may be throwing a few $$$ out
the window, but that's better than a breakdown.
If you haven't already done a front bearing job, you should probably
consider it unless you have the prior owner's records and KNOW that the
folks doing the work did it right.
You'll need the bearing tools. I've chosen to buy bearings from Cinnabar in
the theory that they are most likely to getr the right tolerance bearings.
Timken ships them a special selection from their standard bearings.
Unfortunately they keep the same bearing number wiht no additional
designation. So ... you can't tell from the box whether or not you have the
right bearings.
Henry
fax: (831) 462-5198
