The hub and bearings are press fit so it tends to rock in the knuckle as it
is so short.
When you undo the three bolts, 90% will cause the assembly to drop out.
The top portion of the Knuckle will always wear as the load is there almost
all the time.
We rebuild 98% of knuckles .
Our rebuilt unit assembly are warrantied for 80,000 miles without greasing.
This concept was taught by Roland Wilbur and Ken Toma back in 1985 and I
was privileged to be shown how it is done.
> So does the knuckle get worn from pressing the bearing in and out, or from
> spinning outer races? Something else?
> I'm not detecting any problem with my bearings, so I think I'll leave them
> be as I didn't have to take them apart.
> > It is very seldom the bearing that is worn, but the knuckle.
> > Hard to tell when the wheel is off the hub as you do not have the
> leverage
> > to rock it at 12 & 6 O clock.
> > > Of all the things, I can't find a 12-point 7/16" socket. (it is a
> regular
> > > 12-pt and not a triple-square, right?)
> > > We're in lockdown, can't even go out to the shops. Nothing is easy.
> > > I'll go check some more places for one.
> > > Burl Vibert
> > > Kingston, Ontario
> > > 1976 GMC 26 foot, Sheridan reno, don't know original model
> > > _______________________________________________
> > > GMCnet mailing list
> > > Unsubscribe or Change List Options:
> > Jim Kanomata
> > Applied/GMC, Newark,CA
> > jimk
http://www.gmcrvparts.com
> > 1-800-752-7502
> Burl Vibert
> Kingston, Ontario
