Wheel Bearings Report
larry dtimothy
106
> GMCers
> Well, its been 4 days since I ask for any reports on front wheel bearings.
> I was surprised that most comments came in the back door. I will now
> try to put together a summary of what I have learned. Most of you
> should have seen the one reported problem this time. It was:
> In regards to a "major" front wheel bearing failure, I know of one. My
> father owned a 77 Birchhaven with ~ 85K on it. He was trying to sell The
> Birchhaven, and had it on a lot (he had "upgraded" to a 74 Sequoia with only
> 43 K on it).
> We went to pick it up, and I was following the coach and observed from a
> "normal" distance (I first noticed it from nearly 200 feet) back that one of
> the front wheels had a major wobble to it. Stopped checked it out, the tire
> was worn rather severely from the wobble. Nursed it home, and proceeded to
> rip the front end apart.
> We found that one of the front wheel bearings had a cracked race. The
> bearing was totally destroyed. For that matter we had a real fun time of
> pulling what was left of the bearing out of the carrier.
> We believe someone either dropped a wheel into a deep pothole at speed, or
> hammered a curb.
> And remember Les and Des had a problem last time that may have been
> caused by bad bearings.
> NOW FOR THE REST OF THE STORY
> My coach has 75k miles on it. Still had original bearings when I had them
> replaced at 68k Slight frosting on the original
> bearings. Coach had been used by an entertainment company in So. Cal. in the
> late 70s with a heavy load of people. The last
> owner DID NOT have the bearings serviced for at least 35k miles. Grease
> appeared to ordinary type.
> I've talked to 5 different companies that have serviced GMCs since at least
> the early 80s (one just started recently) I'd
> guess that all told they have serviced a few hundred GMCs - no bearing
> failures, but some bearings needed to be replaced.
> Bought '78 Kingsley in '92. Had no idea what was going on, no books, no
> nutin'. Drove about 20K, then found out "the front wheels come of if you
> touch them wrong". (That was at 42K miles.)
> Tore 'em down, they'd been replaced before, and the hubs were worn down, but
> not it was old news. Built 'em up, which didn't take much, put in Cinnabar
> 'super good, exceeds-specs-of-brand-new' bearings. Regular grease, new
> superboots. Thought that would last 40K miles.
> Kept hearing about 20K replacement REQUIREMENT, or you'd be walking. This
> year at 76K thought the world would end if they weren't changed. Checked for
> play. No slop. Decided to take them off anyway. Couldn't see a single thing
> wrong! Put the whole thing back together and put the spare set of bearings
> in a zip-lock with desiccant.
> Looked at a coach in Watsonville Ca, 74k miles. Original bearings. NEVER
> serviced to spec. Repacked at 25k intervals.
> >The head mechanic for the local GMC dealership lives in one of my rental
> >units. His assessment was the "Toro front end was built like a tank."
> That's what I heard from every mechanic I talked to. My buddy said he never
> saw a problem that couldn't be traced to serious
> abuse.
> Arch I think you have exposed one of the biggest myths surrounding the GMC
> motorhome. I heard the same thing about the Toronados in the late 60's
> early 70's, but when I tried to get more information found out it was just
> rumors. These bearings are large and very well made. They may seize up and
> cause some real problems but we know how to solve that problem.
> Well, folks this aint no fancy survey but it honestly is all I got. Either
> nobody wants to talk of the problem just aint happening.
> That's what I know.
> Take Care
> Arch
Maybe not fancy Arch,
but very informative! Certainly more logical than I had previously
percieved. GOOD JOB!
Tim Timothy
'73 ?Glacier?
Pensacola, Fl.
> GMCers
Sorry to be late but 4 days is a litte quick.
I have owned a '73 since new and have 76k miles. Needless to say it has
set idle for long periods. I have never had a bearing "failure" as
such. However I have had to replace a couple of knuckles and hubs in
that time. Can't remember the details now but the first was before 35k
This was before the availability of special tools and all the help we
have now.
Ted Schurman
73 Glacier VA
> GMCers
> That's what I know.
> Take Care
> Arch
Thanks a lot for taking the time and trouble to compile the informal
survey, Arch.
I, for one, really appreciate your efforts at disspelling some of (now
obvious) myths of the fragility of some of the GMC MH components.
On another note re engine replacements, I recall chatting with another
GMCer at Marion. He had just had his 455 replaced with a "Pro-built"
engine from Dick Paterson in Ontario, CA for around $7k Canadian just prior
to attending the rally. That's installed. FWIW
BTW, he reports that Dick personally pulls and installs the engines, with
the aid of a helper.
As always, best regards.
~ Ritch & Betty Hwang ~ mailto:rhwang
~ =^..^= Trinket ~ the shy Persian kitty
Clarkston, MI
~ 76 GMC Birchaven ~ FMCA 249339 ~ RVClub 00930 ~ ICQ# 6408591
(B}>
