Glenn,
Good to hear you got your new rims, I have customers waiting.
The powder you refer to is used by truckers because their tires are usually
so screwed up and are being used so much that the powder helps to keep them
from bumping down the road. It positions itself the same way the
Centramatic rings work. It will probobly help somewhat.
I would prefer to attack the problem in a different way but if you are
happy with the ride, then ride-on!
Let me know how the higher pressure works out, the tire is rated for it and
I have seen conflicting views on this.
Thanks for the input,
Jim Bounds
>your shortest trip to a smooth ride.>>
>Today, I had my recalled Alcoa wheels (rims?) replaced by the (7) new ones
>that Alcoa had sent to me. As the tires were being demounted from the old
>wheels, the tire man asked me if I had Equal in the tires. Say what? I
>didn't know what he was talking about.
>When he got the first tire off, sure enough, there was Equal in it. The
>stuff looked like fine white sand. He explained it self balances the tire
>and does away the need for weights on the wheel. He said many of the
>truckers around here use the stuff and swear by it; not only does it give a
>smooth ride by keeping the tires in constant balance, it also extends tire
>mileage by a very substantail amount.
>All my tires had Equal in them. The material had to be vacuumed out since
it
>was contaminated during the demounting/remounting process.
>Since they spoke so highly of the product, I had them re-install Equal in
the
>newly remounted tires. It was a Les Schwab Tire store, and I was confident
>they would stand behind the product if, for any reason, it didn't perform up
>to snuff.
>It takes a special pressure applicator, and the amount of Equal must be
>measured for the application. In the 225/75 R16 tire, it takes 3 oz. of the
>material, and is installed through the valve stem. Kind of fun to watch.
>Maybe it's all smoke and mirrors, but I'm looking forward to a smooth ride
at
>any speed with Equal, and no shimmys or shakes between 100 and 200 mph... as
>the race drivers claim.
>Equal costs a little more than traditional balancing ($10 v.s. $7) but, if
>you can believe the claims, it may do a better job long-term. I'll report
>back in about 30,000 miles. Promise!
>One more thing; I had them fill the tires to 80 psi, and was very pleased
>with the ride on the way home. I'm also comforted now, knowing that each
>tire is safely capable of carrying 2,680 lbs. They are Michelins with
>polyester sidewalls; maybe not blowout proof, but I've been told they are a
>lighter tire, more flexibile, and have superior heat dissapation to defend
>against catastrophic failure (as compared to an all steel tire... Goodyear
>G159; Michelin XPS Rib) and cheaper, too. To each his own.
>Glenn
>78K OR
>High on Alcoa and Les Schwab Tires (throughout the northwest)
Jim Bounds/Co-op Motor Works Orlando www.gmccoop.com
Jim Bounds
it
the
>to snuff.
at
>Glenn
>78K OR
