Well, I'm finally back on it and still facing the same issue - no power. I almost started a new thread but then all that courteously responded to
this one would start all over and I'd have to answer all the same questions again.
Here's the backstory - two years ago generator was running fine, both A/C's on and cooling and I stepped away for a bit and came back to find
generator had stopped. Turned off A/C's and restarted, now no power coming out. Since it died with a load, suspected bridge rectifier had failed.
Then life got in the way and this problem went unaddressed since then. I've started and run the engine and driven it periodically during that time
but that's all I had time to do. And fortunately it still starts and runs fine.
So back to the generator and the rectifier - as I went to pull it out, I saw a wire off the lower brush housing. Wasn't sure if I pulled it off
accidently but pushing it back on was way too easy so it either fell off on its own and which would be my good luck, or I bumped and it came off.
Tightened the quick disconnect and pushed it back on, started the generator but still no power. Oh well, one can hope!
So I finished pulling the rectifier, tested it and found all diodes open, or so I thought. Bought a new one and just out of curiosity, tested it as
well and got the same results!! WTH! Changed the DVM to the 20k scale and diodes measure 9k ohms in one direction and open in the other. Checked the
old rectifier - same results! Turns out cheap DVMs don't put out enough voltage on the lower scales to pass current through a diode!
So anyway, back to my problem. I decided to check the condition of the lower set of brushes and found one with the wire misrouted and keeping it from
fully extending. I corrected that and with fingers crossed, re-installed and restarted the generator. Nope - no joy!
I spent some time reading all other 'Onan with no power' threads and it appears the only thing I haven't tried is flashing the thing. What I'm unsure
about it how do I determine F1 and F2? In all the reading I've done today, I haven't spotted the answer. I do read 38 ohms across the windings so
I'm not dealing with a short or open.
Something to keep in mind, it was 2 years ago when I started this thread. The generator at that time had not been run in some time (months) as I was
chasing a control board problem. I replaced the control board with one of the new Dino models and was running it when it died and then lost power.
Now it's been sitting for two years but still starts and runs smoothly.
So should I flash it?
Another question though, does the control board play any role in this power generation. I would think it does and that's the one thing that was
changed before this occurred with a new dino board. Could I be looking at some issue related with changing the board?
1978 Eleganza II
1978 Eleganza II
