With the GMC that I'm selling. It's at just over 100,000 miles. Shifts gre=
at. I changed the trans fluid. The fluid that I removed was very clean. Wi=
th very little on the bottom of the pan. Do I trust that tans? Yes. BUT ho=
w long? ( I was just asked if it's good for 6 months/6,000 miles.) There=
are lots of trans out there that are way be on the 100, 000 miles, and sti=
ll going strong. For me. It all comes down to YOUR COMFORT ZONE. Mine's sho=
rt as you all know. I've been telling prospective buyers that it's fine. B=
ut all trans are perfect just before they quit. But I have a good trans sho=
p here that's experienced with our GMC's. Will pull, rebuild, and install f=
or about $2,000. They did Jay Hodges GMC last Fall. I think the $2,000 is=
a good price. Rather then the road/towing cost. I haven't greased the fron=
t wheel bearings. I'd do that for $350. I'd trust this GMC for years except=
for these two things. I'm asking $18,000 for this reconditioned GMC. So yo=
ur thoughts? Bob Dunahugh My ad without pictures below. JUS=
T COMPLETED restoration. Bought it to fix up for our daughters family. Then=
a medical issue came up for her. Pl. Sell. This 73 Canyonland has =
just had the entire interior removed, refinished as needed, and reinstalled=
. Cabinets, and drawers have been reassembled with glue, and screws for d=
urability. Interior of closet drawers have been sanded. And a coat of cl=
ear urethane applied for a clean surface. The closet had been lined with=
Cedar. New modern looking counter top. New plywood ceiling that has a mold=
, and mildew resistant coating applies to both top, and bottom sides. Real=
Walnut paneling installed from the door forward. A high end cloth headlin=
er that is used in custom built Winnebago motorhomes has been installed. =
With 8 LED recessed lights. These lights are controlled by wall switches. B=
ed area, and hall lights can be turned on at front door. Then turned off fr=
om rear bed. All new under cabinet lights are LED's. Two Fantastic ceiling =
vents units in ceiling. One is new. TV coax cable, and USB ports installed =
at front, center, and rear of couch. Newest in electronic 110 volt to 12 v=
olt converter installed. More 110 volt plugs added. New window treatments. =
$2,400 spent on all cushion/seats. New flooring. Built in micro wave cabi=
net. These next items are also new. Roof A/C unit, Magic Chief 4 burn=
er cook top, Domedic frig/freezer, Sur flow water pump, and a replacement=
Suburban furnace. These appliances where replaced at a cost of $2900. Outs=
ide paint is older. But nice. Mechanicals. New 16" American Eagle r=
ims. With Dunlop tires. 6 new KYB shocks. Both gas tanks flushed, and insta=
lled with new gas tank sending units. With new rubber gas line. New exhaust=
tail pipe. Complete 78 rear suspention, and brakes installed. All brake h=
oses replaced for safety. Main frame is in excellent condition. Cleaned, an=
d painted. Engine oil pressure is good. Compression readings are excellent.=
At 150 to 155 psi. All belts are new. New cam timing chain/sprocket=
s, engine water pump, and front brake hoses/caliper and brake pads. Rear r=
ubber brake hoses with new wheel cylinders, and shoes. Carburetor rebuilt. =
New ignition points, plug wires, and spark plugs. This GMC will be able t=
o travel anywhere in the country.$18,000. I taught Industrial Arts auto/woo=
dworking. Been into GMC's since 2003. I've rebuilt 3 GMC's before this one.=
One for a close friend. And 2 different ones for our personal use. Bob D=
unahugh 319-521-4891 YENKO108 mail.comhttp://mail.com/
