What happened to Duracool? HC-12a?? $$$$
Matt Colie
11,101
807
113
South East Michigan near DTW
Wow,
Tomorrow I am off to service the refrigeration on a clients boat. Years ago I got it going by changing it to HC-12a (brand uncertain but probably
Duracool). I know that his system may need more than a single can, so I went on-line shopping.....
10 to 14$US per can!! I can actually buy real Dupont R-12 for that much now.
This is what I use with success
http://www.frostycool.com/FrostyCool-r12a-refrigerant-replacement-for-r-12-freon-substitutes-18-oz-equivalent-1-case-12x-cans/
bdub
On Tue, Sep 8, 2020 at 2:52 PM Matt Colie via Gmclist <
> Wow,
> now.
> Matt
> GMCES
The cost has gone up because it is more popular now.
Don’t forget that you only need about 3 cans of Duracool vs. 6 cans on R-12.
So, its still 1/2 as expensive as R-12 and it works better.
You can find equivalent brands to Duracool for about 6 o 7 a can in case quantities.
Frederick, CO
> Wow,
> Matt
Just ordered 12 6oz can. My Birch has R134 conversion and it has mostly leaked off in five years.
After i put a vacuum on it and find the leaks, How much Duracool should it take ?
Dave & Ellen Silva
1972 Revcon Olds 455, toro drive train. All Stock
3 cans max
Sometimes just a little less than 3 cans.
Frederick CO
> Dave & Ellen Silva
Dave:
If you can, you might be better off doing a nitrogen purge before pulling the vacuum and recharging the system.
I’ve always find it easier to “spray for bubbles” when looking for leaks.
My .02
Dolph
DE AD0LF
Wheeling, West Virginia
1977 26’ ex-PalmBeach
“The Aluminum and Fiberglass Mistress”
"--OO--[]---O-"
> Dave & Ellen Silva
I recently replaced all the O rings but after pulling a vacuum I found it would slowly leak down. I wanted to pressurize the system to check for leaks. I didn’t have a nitrogen tank so I used compressed air. I drained off all condensate from the tank and charged the air conditioner to 20 psi. I found my leak with soap bubbles but it was at the connection of the low pressure hose from my gauges. I tightened it with pliers and the leak stopped. Realizing that in addition to the air I also had introduced some moisture, I left the vacuum pump on all night. I then charged it and no more leaks
Frederick CO
> Dave:
> My .02
> Dolph
> DE AD0LF
That sounds like a plan!
I get a kick out of watching the little puffs of moisture that the vacuum pump successfully drags out of even the best kept system.
No substitute for a good hard vacuum on a refrigeration system!
Dolph
DE AD0LF
"--OO--[]---O-"
> Emery Stora
> 77 Kingsley
> Frederick CO
>> Dave:
>> My .02
>> Dolph
>> DE AD0LF
