Rick,
Don't forget the thermostat only controls the temperature in the engine.
The efficiency of the radiator will control the temperature in the discharge
tank where the tranny cooler is located. Before I lost my tranny pan temp
sender, my pan temps were in the 130 degree range. That's a Cad 500
with an aluminum radiator pulling a 4-door tracker here in the flatlands.
No one, including me, has bothered to check the discharge temp of the
aluminum radiator to know how good it really is. But I like it, yes I do.
Gary Kosier
77PB w/500Cad
Newark, Ohio
Sent: Wednesday, July 05, 2017 3:13 PM
To:
Subject: Re: [GMCnet] What do those in the hot SW do for engine thermstats?
> Yabbut, that radiator is also cooling the transmission. I'm not sure
> there's much of an efficiency difference in the engine between 180 and
> 195,
> but if the 180 keeps the tranny 15 degrees cooler also, then that's okay
> with me.
> Rick "stirring the pot" Denney
> On Wed, Jul 5, 2017 at 1:38 PM, Ken Henderson
>> Bob,
>> You're going to get all kinds of opinions on thermostat temperatures,
>> from
>> none, to fixed orifice, to 165*F on up to the RECOMMENDED 195*F.
>> Remember
>> that higher operating temperatures, regardless of what you may hear, =
>> higher efficiency. Later model vehicles run even higher for that reason.
>> I do, and will, stick with GMC's 195*F. And my Cad 500, with aluminum
>> radiator, runs at 193*F to 197*F under almost all circumstances,
>> coast-to-coast, towing or not, mountains or not, hot or cold ambient.
>> JWID,
>> Ken H.
>> On Wed, Jul 5, 2017 at 1:26 PM, Bob Dunahugh
>> > My new Digi Panel in our latest 78 Royale is showing higher temps
>> > then
>> I
>> > was running in our former 78 Royale. Now on this trip. The temps have
>> come
>> > up a little more. I think this latest increase is a thermostat issue.
>> The
>> > 403 now has about 6000 miles on it. The thermostat is a 195. I'm
>> thinking
>> > of dropping that temp. We don't leave when it's real cold. Our GMC
>> > sets
>> in
>> > it's garage that's at 70 degrees all year long. If we leave on a
>> > cooler
>> > day. The engine isn't needing to come up from -35 below. So does 180
>> > seem
>> > right for my situation? I'm also thinking that during the rebuild
>> > that
>> > the PO had done. The builder put a car water pump in. Think the water
>> > pump is coming up. Bob Dunahugh
>> http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org
> '73 X-Glacier 230 "Jaws"
> Northern Virginia
> Offlist email: rick at rickdenney dot com
Gary Kosier
77PB w/500Cad
Newark, Ohio
To:
> 195,
> with me.
>> Bob,
>> from
>> Remember
>> JWID,
>> Ken H.
>> > then
>> I
>> come
>> The
>> thinking
>> > sets
>> in
>> > cooler
>> > seem
>> > that
> Northern Virginia
