I have seen too many filled in intakes that never stayed in place.
The SS block of plate and gasket by Dick Patterson has been a dependable
set up we sell .
> There is only 2 kinds of cast iron. The kind that is already cracked, and
> the kind that hasn't cracked yet. So where does that leave us? Looking for
> an uncracked intake manifold, or figuring out a way to mitigate an already
> cracked one. If it is not cracked into the intake passage under the
> Carburetor, there are a few ways to mitigate it. Welding is one way,
> sometimes successful, sometimes not. I won't go into details here. Another
> way is blocking off the crossover passages. Another is to pour aluminum in
> the crossover.
> I personally prefer to find an uncracked manifold, and blocking off
> the crossover using Dick Paterson's stainless steel plates and his special
> gaskets. Some manifolds have enough room at the ends to use the neoprene
> dams at each end. If the heads have been cut, or the deck surface machined,
> then there may not be room for the dams. In that case, "The Right Stuff"
> silicone sealer will work on the ends.
> I hate the turkey tray intake gasket. Really difficult to install.
> Jim Hupy
> Salem, Oregon
> > After installing a couple different intakes.
> > Please trust me and you simply want dick paterson’s intake block off
> > plates and gaskets.
> > I dont know where he gets his gaskets(i think he has them custom made).
> > They just fit. There is just not much room for error. The intake
> is
> > not as simple as it should be as far as getting the gasket, heads and
> > intake ports to all line up. But the couple patterson gakets i have
> > installed
> > vs the coop supplied mr gasket 404 and modello plates were night and day
> > difference.
> > As far as the job, you want good handles on intake to raise and lower
> and
> > make an alinement bolt(bolt with head cut off and used to guide.
> > Also most are so full of sledge underneath, that you need to buy a cheap
> > shop vac and sacrifice it to the job of cleaning out all the crud.
> > I am surprised jim bounds did not block that crossover during the
> original
> > restoration of the coach. He used to talk about doing that way back
> then.
> > Jon Roche
> > 75 palm beach
> > EBL EFI, manny headers, Micro Level, rebuilt most of coach now.
> > St. Cloud, MN
Jim Kanomata ASE
http://www.gmcrvparts.com
