What did I do wrong - new axle no torque
XPlorID
Member
Feb 9, 2012
183
16
Just to close this problem thread, it turns out the drivers side axle nut was loose and ruined the wheel bearing (1-ton conversion). That was causing
drag and the coach was steering itself left.
With that fixed I am back to a bit of torque steer, which I have been fighting forever.
Jeff
1974/94 GMCII by Explorer
Manny 6.5 TD Al radiator
1 ton front 4 bags back
Jeff
I think torque steer is common to almost all front wheel drive vehicles!
The harder the gas pedal is pushed, the greater the effect!
D C "Mac" Macdonald
Amateur Radio - K2GKK
Since 30 Novemb'53
USAF and FAA, Ret'd
Member GMCMI and Classics
Oklahoma City, OK
"The Money Pit"
TZE166V101966
'76 ex-Palm Beach
k2gkk + hotmail dot com
wwww.gmcmhphotos.com/okclb
Sent: Monday, March 21, 2022 15:05
Subject: [GMCnet] Re: What did I do wrong - new axle no torque
Jeff
Not exactly. As time has progressed form the early 70's, engineers have discovered how to minimize torque steer. Even modern high powered vehicles now have a minimum of torque steer. My V6 Mazda 6 will only exhibit torque steer under extreme throttle and even then is completely controllable. Not like early Tornado's which were death traps on slippery roads.
CJ Vermeulen, Scribbler
To: "gmclist"
Sent: Monday, March 21, 2022 3:24:33 PM
D C "Mac" Macdonald
Since 30 Novemb'53
USAF and FAA, Ret'd
Oklahoma City, OK
"The Money Pit"
TZE166V101966
'76 ex-Palm Beach
Jeff
It has a lot to do with front track width, front to rear weight bias, front
ride height, differential ratio, horsepower or perhaps more accurate,
torque, and finally alignment and condition of steering system components.
Some things that I have found useful on GMC's is camber and toe out.
Also, no wide offset wheels. But, they all will exhibit torque steer on
steep uphill, and particularly when the wheels are not pointed straight
ahead.
Salem, Oregon
> From: "K2GKK D C_Mac_ Macdonald"
> To: "gmclist"
> D C "Mac" Macdonald
> Since 30 Novemb'53
> USAF and FAA, Ret'd
> Oklahoma City, OK
> "The Money Pit"
> TZE166V101966
> '76 ex-Palm Beach
> From: jeff sugheir
> To: gmclist
> fighting forever.
> Jeff
