Donald..........Isn't water a lubricant under these conditions, like driving
through a puddle? Also, wouldn't rapid cooling like that produce warpage of
discs.........Jim Davis
- -----Original Message-----
To: gmcmotorhome
Date: Sunday, August 02, 1998 12:13 AM
Subject: GMC: Water Cooled Brakes
>This idea is so neat I wish I had thought of it.
>A Can-AM race team uses a windshield washer pump and a pair of nozzles to
>squirt some water on their front brakes to cool them. They use the same
>system on their Class A motor home when in hilly terrain.
>Turning a small amount of water to steam soaks up a lot of heat.
>Power for the pump is from the brake lights circuit through a dash switch.
>When dash switch and brake lights are both on, the pump squirts water on
>the brakes.
>Another thought is to use the 40 gallon fresh water pressure system with a
>solenoid valve controlled by the brake lights.
>May not be as good as six wheel disk brakes but certainly a lot less
>expensive.
>Anyone see any problems with the idea ?
>Don
To: gmcmotorhome
>the brakes.
>expensive.
>Don
