I had a Westberg tac prior to getting my Mac dash and never had any problems with it. I then installed it into Walter Drew’s GMC. Walter lived in Santa Fe. I don’t remember who bought his GMC but it’s someone on this net.
Last summer I burned up 3 coils. I found that there was an intermittent short between the hot lead in the distributor and the tach lead.
After I replaced the wiring harness leading to the distributor it solved the problem.
Frederick CO
> Dolph,
> I might do that ('tho' I don't think it's the source of the problem -- I've
> NEVER blown a module) if I hadn't given my 'scope to my grandsons. Next
> time I have the coach there, I'll do it though.
> Ken
> On Sun, Jun 16, 2019 at 6:13 PM Adolph Santorine via Gmclist <
>> Ken
>> Put your oscilloscope on the DC coming out of your alternator.
>> My erratic tach readings and blown modules were induced by an alternator
>> that was sporadically making AC. Eric Tanner fought the same issue.
>> Dolph Santorine
>> DE AD0LF
>> Wheeling, West Virginia
>> 1977 ex-Palm Beach TZE167V100820
>> Howell EFI/EBL , Reaction Arms, Manny Transmission
>>> On Jun 16, 2019, at 6:05 PM, Ken Henderson via Gmclist <
>>> That's not an unusual occurrence. My engine began to miss on a trip a
>> few
>>> months back. Since the tach had been a little erratic, I immediately
>>> suspected it and disconnected it from the distributor. Engine hasn't
>>> missed since. That was a several year old VDO, which I haven't yet
>>> replaced. That's not the first one I've had trouble with, and John
>> Beaver
>>> tells me it's one of the first suspects when they have trouble with
>> racing
>>> engines.
>>> Ken H.
>>> On Sun, Jun 16, 2019 at 1:04 PM Gary Worobec via Gmclist <
>>>> After having the coach die on two occasions and changing out the coil
>> and
>>>> module in the HEI distributor with no avail I checked in with Dick
>>>> Paterson. He suggested the tach wire to the HEI high might be the
>> problem.
>>>> Guess what, that is what it was. I did trace the wire back to the
>> Westach
>>>> tach/vac combo gauge that a bunch of us bought on a group buy a way
>> while
>>>> back. The wire was good. Looks like an internal failure in the gauge.
>> I’m
>>>> leaving the gauge in with the vacuum part and adding an Autometer 0-6000
>>>> rpm 2 3/4” inch gauge mounted on top of the horse collar.
>>>> Thank you so much Dick Paterson for always being there for us.
>>>> Gary
>>>> 1973 Glacier 23
>>> _______________________________________________
>>> GMCnet mailing list
>>> Unsubscribe or Change List Options:
