Bill Guise: billg Seattle, WA=20
Ok, I admit it! Have brake problems and I am baffled. Installed Eaton =
system, everything fine for the first two trips, then split a rear steel =
line and that spelled trouble in getting the system back on line. Have =
been working on and off the problem for three months!
Replaced the broken line.
Bled system, but no pedal
Bled about 5 times, no result
Gravity bled, no results
Reverse bled, no results (Pressure from each wheel)
Removed lines to Master cylinder, plugged outlets, MC ok.
Bled lines once more, no sign of air.
Adjusted rear brakes all the way tight.
Brake pedal is normal when engine off
Engine on, pedal goes=20
all the way down, about 1" to floor, can hit the bottom with excess =
pressure
All lines are new, inspected for balloon lines, all are ok!
Any Suggestions? (Have handicapped booster installed)
Bill Guise
pressure
Bill Guise
