Water system
hdavis
518
>GMCers
- -snip
>You had a problem when the pipe between
>the city water inlet broke because of stress on it.
>today
>I found the answer but could not find your mail. Hope you are still here.
>On the back of a Shureflow water inlet install a 90 degree Quest elbow
>for 1/2 inch tubing. This fitting has the right threads to match up to
>one of the new braided hoses used to install hot water heaters. Put
>in a tee in the cold water line that has the same 1/2 inch coming out the
>top. Put in what ever amount of 1/2 cros-pex you need and a 1/2 inch
>coupling then the water heater flex hose will connect to it. No stress
>no problem.
Arch,
I also posted about the city water inlet. My inlet cracked due to stress.
My solution is the same as yours. I'll let you know how it works this summer.
Henry
Soquel, Ca 95073 / IP reviews
fax: (831) 462-5198
