Last summer I ordered a heavy duty waterpump from Winterfeld.
It turned out to be a TRW FP-1524HD. Both of these are listed in the
GMCMI Parts Interchange Index. I suggest that you stick with this and
forget NAPA etal. When my engine was replaced by the factory many
years ago (long story) the wrong waterpump ended up on the engine and
I suffered many years of overheating. I think that problem is gone now.
BTW, a word of warning. The waterpump is mounted on a plate. The top
of the plate is not fastened to the engine. In removing the
waterpump I missed a small bolt holding the pump to the plate.
I thought the pump was just stuck to the plate and in encouraging its
separation managed to break the seal between the plate and the block.
I did not know this until everything was back together and I had
coolant in the crankcase. It is impossible to replace the gasket
between the plate and block without a lot of work so I tried a liberal
amount of sealer. It seems to be holding. Probably not the first or
last to do this but it does seem like a bad design not to secure the
plate to the block
Does this qualify for confessing a dumb mistake ?
Ted Schurman
73 Glacier VA
> In a message dated 12/9/98 10:46:58 PM Eastern Standard Time,
> > My sources do not have a special # for the larger impeller, it seems to be
> > a matter of luck.
> I had the same problem in finding my water pump. I tried Napa , they carry
> water pumps, however after 3 trys of delivering the stamped steel water pump,
> I went to a different auto parts store. This time I specifically asked that
> they open the boxes, explained that I wanted a cast iron impeller. They had
> two water pumps, one stamped steel and the other cast iron. Mind you they all
> had the same number. The counterman did not realize that this could be
> possible. So I agree with Jim Bounds---- It seems to be a matter of luck---
> But this luck would improve if you would have them open the box first before
> trecking to the parts store.
> Scott Nehoda Adohen
http://www.bytedesigns.com/nehoda t=_self]HEINZ NEHODAS BACK YARD[/url]
