Matt,
Thanks!
My problem was that the only time I've ever heard the word "sheaves" was in the hymn, "Bringing in the Sheaves."
I didn't know that it also can refer to a pulley. I hadn't thought to Google it until I read your response below.
https://sciencing.com/difference-between-pulley-sheave-8533603.html
Regards,
Rob M.
The Pedantic Mechanic
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Matt Colie
Sent: Tuesday, April 3, 2018 6:59 PM
Subject: Re: [GMCnet] Water pump pulley needed
> Matt,
> You lost me!
> Could you please explain this a bit more:
> "the fan clutch really does not load the water pump shaft as it is fastened to the water pump sheave."
> Regards,
> Rob M.
Rob,
Apart from the possible change in the horsepower load of FEAD (Front Engine Accessory Drive) the only load on the water pump shaft
is the pumping
load. As this fan is actually better balanced than the original (at least mine sure was/is) so that just is not likely to be any
issue. The sheaves
and the fan adapter are all fastened to the water pump drive flange.
