Water pressure regulator
pickle4k
17
1
Does anyone know the make and model of the water pressure regulator off an Avion water heater? Mine has developed a leak and needs replacing. The leak
has obscured the label. Fortunately it only leaks when the pump is on. Thanks for your help.
Nick R. NorCal
76-23'Transmode-Norris
Rear Bath and
75-26' Avion
Nick,
Long time no see! You want this one here from Grainger, it should be direct replacement:
https://www.grainger.com/product/GRAINGER-APPROVED-3-Way-Brass-Series-2-1-8-L-30PV11
This is a 3 port, just plug the 1/4” gauge port. The watts original is no longer available for water service.
JR Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 30’ Stretch
Michigan
> Nick R. NorCal
> Rear Bath and
> 75-26' Avion
​Nick,
I believe what you need is the pressure relief valve.
They come in 1/2" or 3/4" 150 PSI and 210 degree​
> Nick R. NorCal
> Rear Bath and
> 75-26' Avion
Applied/GMC, Fremont,CA
Hi JR, thanks for the reply, but the info on the regulator did not show in your post.
Nick R.
Nick R. NorCal
Rear Bath and
75-26' Avion
The hot water heater in the Avon is an Atwood 6 gallon electric only model (with engine pre-heat tube). If you decide to replace it, use only the
Atwood made model. Replacing it with any other hot water heater is an extreme PITA. None of the water fittings or electrical fittings are in the
'right' place. It took me several times longer than reasonably expected to replace a defective hot water heater on my Avon. Bottom had rotted out the
bottom of the tank.
The space for the hot water heater is also very tight, with very limited wiggle room.
Tom, MS II
1975 GMC Avion
KA4CSG
