"Can anyone tell me where the hose from the water nipple behind the right
rear wheel goes back to? Every time I turn on the pump, I get pool from what
I think is probably some sort of pump pressure or priming system.. Found
copper nipple behind wheel, but no evident line or hints as to where it
might once have gone to.."
J.Dexter,
My coach is back in the storage lot now, but IIRC there is a drain valve in
the right rear compartment next to the water pump. Opening the valve and
running the pump sends pressurized warter out through the little drain tube
(red plastic on my coach). The drain cock in the right rear wheel well is
for my water heater. Check the "Living Area Water System" illustration in
your owner's manual (mine is on page 39).
Good luck,
Peter
Colorado
J.Dexter,
Good luck,
Peter
Colorado
